my car will not start
Guest
Posts: n/a
I have a 2000 s type with 115k miles on it, i have treated my car with good care. Although as of last night i hates me... the damn thing wont start. Anyway i have determined that fuel pump is not receiving voltage ultimately restricting fuel from getting to the engine. I have checked all the fuses and found that 1 - 6 located on the bottom of the passengers seat also dont light up when being tested but every other fuse does. I dont know what they are since I seem to have also misplaced my users manuel... any suggestions?
Guest
Posts: n/a
You can find a copy of the manuel at jaguar.comI had a car do this to me once and i determend that i had a bad ground. Instead of rewireing the whole ground i just ran a new one direct to the battery. If worse comes to worse you will just have to rerun the fuel pump wires. Or hard wireyou pump to the battery and drive it to a shop then pull the wires and have them fix it. lol Good luck Also could be a main fuse or relay. oh well thats my twocents worth.
I don't see why, but maybe the fuel cut-off switch was activated. Look at the drivers side kick panel and you will find a hole big enough just for your finger, assuming you're not overly obese, which in that case you'll need someone to put their finger in there and reset the switch. BTW, guitarman is right, a faulty ground affects the fuel system first.
BrentGardner
29
Dec 16, 2024 12:13 AM
1964Daimler
Sep 2, 2015 11:41 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
