Need help with S Type push in compartment by radio
Old Jan 23, 2012 | 04:57 AM
police666's Avatar
It looks easy, pdf made from jtis, removal instructions.
File Type: pdf
Old Jan 23, 2012 | 07:51 AM
tonyvisone's Avatar
great link.... very helpful, thank u very much. i will get to this when i finish fixing a few other things
Old Jan 23, 2012 | 08:07 AM
JagV8's Avatar
Didn't you already get and look at JTIS?
Old Jan 23, 2012 | 08:08 AM
police666's Avatar
it's from jtis, a must have download. get it here
https://www.jaguarforums.com/forum/x...archive-66034/
Old Jan 23, 2012 | 08:09 AM
police666's Avatar
jagv8 posted as i was typing
Old Jan 23, 2012 | 08:41 AM
Gus's Avatar
Gus
I removed my unit and it is easy just remove your cover “D” on both sides and the one at the bottom and you will find bolts under them. Now to remove the unit you will need to put your shifter in “D” to do that. Do not pull on the unit hard because you have wire in the back for the radio and heat & a/c. I removed the shifter ball to make the job easier. I hope this helps.
I guess I was a day late and a dollar short on this one….
Old Jan 24, 2012 | 12:40 PM
tonyvisone's Avatar
will "D" come out by prying it? i dont wanna break it if not... and r u sure that frame will come out if i do that? there appears to be screws coming from above and below it on the inside. let me know, i hope your right
Old Jan 24, 2012 | 02:58 PM
  #28
It should, have a look here https://www.jaguarforums.com/forum/s...003-faq-36719/
this is the later car but I believe that it is the same set up.
philwarner
Oct 4, 2024 01:37 PM
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
