No Code: Brake Assist Failure Lamp
Old Apr 27, 2025 | 09:21 PM
KLinRaleigh's Avatar
Default No Code: Brake Assist Failure Lamp
Well...seems the dash continues to show a "Brake Assist Failure" statement, with amber lamp illuminated, on the 2006 S-type (3.0) base. No codes are being generated, nor are there any stored, or other permanent codes relating to this (or any other system notification). I ran my cheapy Craftsman OBD, and my OBDII MX+. Both show all being well in the Jaguar jungle. I cleared and tested several times throughout the driving day. I believe I made three separate 3-5 mile trips today, each time checking, clearing and checking per the instructions (ign on/eng off, etc.).
The brakes feel very good underfoot, with the car stopping well within expectation, equally and positively.
I am not a brake professional, though believe this system is mechanically correct. I should mention that I'm also able to hold the pedal firmly without loss of pressure (does not fade slowly to the floor), nor is the any apparent fluid leakage (floor, wheels, reservoir).
Thoughts of any kind?
Thank you!
Old Apr 28, 2025 | 12:45 AM
xalty's Avatar
06+ V6s have a vacuum sensor on the brake booster that the V8s don't need, it ramps up line pressure in low vacuum. 99% chance it's gonna need a booster, you might be able to take the sensor out and swap them from the used to the new but be ready to do the full job.
either way get a better scan tool that can read the DSC module next time. thinkdiag mini is cheap will read all modules
Old Apr 28, 2025 | 06:23 AM
JagV8's Avatar
There will be codes but you're using tools which only read emissions stuff. Can't blame them for not reading anything else.
Old Apr 28, 2025 | 12:05 PM
Ordered the Thinkdiag2..Greatly Appreciated, X.
Old Apr 28, 2025 | 12:08 PM
Right. So so glad I had not.
Thinkdiag now on order for early delivery. Let's see what the new unit has to say, shall we?
Crossed fingers it won't add to the Bromwich Sandwich.
Cheers, Kevin
Old Apr 29, 2025 | 08:47 AM
kr98664's Avatar
Originally Posted by xalty
06+ V6s have a vacuum sensor on the brake booster...
Wiring diagrams here:
JagRepair.com - Jaguar Repair Information Resource
See figure 05.1. I think this sensor is called the "DSC Vac Sensor" in the wiring diagram, shown near the bottom of the page. Note how this sensor has two channels. Not sure of the logic that turns on the warning message, whether one or both channels out of range, but it wouldn't hurt to compare the channels.
In the workshop manual (same link as above), see page 446 of the PDF. The diagram shows the sensor as item #5, now called the "brake vacuum sensor":
At the very minimum, make sure the connector is clean and secure.
Old Apr 29, 2025 | 09:22 AM
Thank you, Karl. I'll have a look, removing the connector/cleaning with contact cleaner and replacing..then crossing fingers and all else. Wonderful to have this now saved resource. Thank you very much.
I had to look up Sandy.. I'm from Olympia, but haven't lived there since I was a kid.
Cheers, and thanks!
Kevin
Old Apr 29, 2025 | 10:03 AM
kr98664's Avatar
Default Off-Topic
In your sig, I see you have a 1948 ******. Here's mine, a 1948 CJ-2A in the sand at Long Beach, WA:
Flathead L134, 6V, mostly stock...
Old Apr 29, 2025 | 11:38 AM
clubairth1's Avatar
Community Influencer
I thought they had banned driving on the bench now?
04SCat
May 25, 2023 07:28 PM
David Hawthorne
Feb 23, 2022 02:01 AM
Johnken
Jun 9, 2016 01:47 PM
ant17
22
May 2, 2014 07:47 AM
gxcp
Sep 12, 2010 03:14 PM
