pcm pin #38 location
Old Jan 15, 2013 | 12:36 PM
jaguarlady03's Avatar
Default pcm pin #38 location
does anyone know where pin #38 is located in the PCM. i am troubleshooting a MAF P0102 issue. my next step is to meter between the PCM pin #38 and the MAF pin #4. I have no clue which pin is #38 and cannot find a diagram of pin identification in the PCM....
Old Jan 15, 2013 | 02:22 PM
Thermo's Avatar
Veteran: Navy
Lady03, let me get home and I will look up in the diagrams I have of where you need to look. Do you know where the PCM is located? Just want to make sure that I am not sending you on a wild goose chase when you don't even know what you are looking for to begin with.
Old Jan 15, 2013 | 04:46 PM
ssreyer's Avatar
http://jaguar.bttlxe.com/xtype/Elect...ec%20Guide.pdf
Old Jan 15, 2013 | 05:04 PM
Thermo's Avatar
Veteran: Navy
lady03, I am looking at the diagrams for your car and I am a little confuses as to why you are going after Pin 38 to the ECM. That pin feeds power to the IMT valves, not the MAF Sensor. Based on your name, I am making the assumption that you have an 03 X-Type. But, the engine wiring is identical between the the early X-types and the later ones as far as most of the pin out for the PCM.
As for Pin 38, if you locate the PCM, you will notice that it has a rounded top and a flat bottom. If you orientate the plug on the PCM to this convention and you have the plug still attached to the PCM, Pin 38 is on the second row from the bottom, fourth pin to the left of the center gap. It will be an orange wire with a yellow stripe on it.
If you are after Pin 71 (the other end of the wire that goes to Pin 4 of the MAF Sensor), then that would be in the center row of pins, the fourth wire to the right of center. This is an orange wire (no stripe).
Hope this helps.
Old Jan 16, 2013 | 07:21 AM
i have a 2000 stype
thanks for the info
Old Jan 16, 2013 | 07:30 AM
steveinfrance's Avatar
I've moved this thread to the S-type section + deleted the duplicate there.
Old Jan 16, 2013 | 07:53 AM
JagV8's Avatar
The Electrical Guide has every pin shown. Also colours and connector details. Part of JTIS.
Old Jan 17, 2013 | 06:23 AM
Default pcm pin 38
i have my service manual on CD; however for some reason it does not contain the electrical guide. i will look online for the electrical guide
thanks!
Old Jan 17, 2013 | 10:15 AM
JagV8's Avatar
It's a PDF which helps in google (or searching on the CD)
Old Jan 18, 2013 | 06:15 AM
Default electrical guide JTIS
i understand. my JTIS is on CD. when i click on the electrical guide, i receive a message that states "no electrical information available"
thanks for your help
Old Jan 18, 2013 | 08:03 AM
JagV8's Avatar
Post #9
Old Jan 18, 2013 | 08:34 AM
Gus's Avatar
Gus
See if this oneline diagram helps
Link http://www.jagrepair.com/images/Auto...01999.25en.pdf
Old Jan 18, 2013 | 11:28 AM
JagV8's Avatar
That's one of the ones google should find, though probably too early MY.
google really is worth using... or browse the JTIS CD.
RedRider48
Oct 1, 2015 08:18 AM
MrWhite
Oct 1, 2015 01:43 AM
Paulie710
Sep 28, 2015 03:49 PM
PinnacleWax
Detailing / Car care
Sep 25, 2015 12:46 PM
