Picked up an 03 S-Type 5 speed manual
Old Jan 18, 2024 | 10:14 PM
krsone579's Avatar
Default Picked up an 03 S-Type 5 speed manual
Hey all, Just joined the forum. I've previously owned a 5 spd X-Type and it was a fine car to me. The autos I hear are quite unreliable though. I just picked up an 03 S Type factory 5 speed manual. I thought this was pretty cool, definitely a rare one in the states. Its got 75k miles and is in mint condition, except it needs an engine, one piston is destroyed somehow, as can be seen through the spark plug hole. The plan is to replace the engine with a used one from eBay/ local yard/ car part etc and get it running again. I assume it should be a straight forward engine pull? Has anyone done this before and might be able to shed some light or insight if its not straight forward for some reason.
I towed it to my house and checked in the trunk, new clutch, flywheel, pressure plate, slave cylinder, intake gaskets, and a jaguar 3 liter emblem as well, with a receipt totaling more than I paid for the car. What a surprise I tell ya! So luckily that can all be done at once. For some reason there are two pressure plates, preliminary googling shows one may be for the Lincoln LS, which share many parts, and I would think even the pressure plate so not sure why there are two. I will have to check it out more once the weather breaks (Chicagoland) and I can start working on her.
Well thanks for the read. Hope the forum is still semi active, I know these are getting older now.
Old Jan 19, 2024 | 07:30 AM
S-Type Owner's Avatar
Welcome aboard. You might want to copy the above and post it to the New Members forum, which can be found here:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
This is pretty much expected and will help you gain additional forum privileges.
Old Jan 20, 2024 | 07:03 PM
krsone579's Avatar
Hey thanks for the heads up, I just posted in there now!
Old Jan 21, 2024 | 11:08 AM
NBCat's Avatar
Here is a link to the X202 Workshop Manual:
https://www.dropbox.com/s/aq3872pbu5...kshop.pdf?dl=0
RoadMaster2
Dec 6, 2021 07:13 PM
rhriczko
36
Nov 6, 2021 11:36 AM
Ruddy Brown
Aug 22, 2019 12:01 AM
cel2620xl
Jan 14, 2012 05:03 AM
cleveland
May 22, 2011 06:11 AM
