Radiator leak can't find
Looseing anti freeze but cant locate leak do not see drips anywhere.
Looses about a quarter gal. Every two to three days.
Maybe about 30 miles driving
I've found with the engine running and coolant warm, small leaks often evaporate quickly, making them difficult to identify. I've had good results with a pressure tester on a cold engine.
If you do find an external leak, be careful with the diagnosis. The fan tends to blow any coolant around and it may collect in other spots and steer you wrong. That's why I like the pressure tester, so you're not dealing with potentially misleading results from coolant being blown around by the fan.
dbourg
Mar 21, 2019 02:13 PM
