Rear Tie Rod and Sway Bar Links Replacement
Old Jul 22, 2019 | 05:20 PM
Afraaz3's Avatar
Default Rear Tie Rod and Sway Bar Links Replacement
Hey there, super helpful but I had a question I also have an STR and the parking brake caliper is blocking the room for the bolt to come out. I’ve done minor suspension work on my car but haven’t removed the EPB before. Is there an easy way to do so or a video you can share?
The JTIS manual instructs to use the special EPB software to release the parking cable and I’m hoping there’s an alternative. I would prefer not to have the hassle of retracting the pistons, bleeding the brakes, and calibrating the parking brake just to remove this bolt.
This may be naive, but Is there a simple way to remove the caliper completely without needing to detach the cable or remove the pads?
Old Jul 23, 2019 | 09:47 AM
S-Type Owner's Avatar
You might want to make this a separate new post, as opposed to tacking your issue on to the end of a very old message thread.
Also, it is customary to post an introduction here:
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Jul 23, 2019 | 02:53 PM
Hey there, super helpful but I had a question I also have an STR and the parking brake caliper is blocking the room for the bolt to come out. .....
Welcome to the forums Afraaz,
I've moved your question from the end of an old thread on a related topic to a new thread.
Old Jul 24, 2019 | 10:31 PM
scottjh9's Avatar
If I remember right ......start car.....hold park brake to release position with one hand, and while holding it, turn car off and remove key....it will remain released until car is started again....I do not know if this method works with the brembo brake set up with the separate park brake caliper
Old Jul 25, 2019 | 01:19 AM
JagV8's Avatar
It works fine with that.
joycesjag
54
Jan 29, 2025 09:33 AM
04xtype04
May 4, 2014 09:27 PM
SamOscarBrown
Nov 4, 2013 08:16 PM
EZrider800
May 24, 2012 08:16 PM
morrison
Feb 5, 2012 06:58 AM
