Replaced the entire suspension on my STR, plus High flow cats and pulley...like new!
Old Aug 10, 2014 | 05:33 PM
08Z06's Avatar
Default Replaced the entire suspension on my STR, plus High flow cats and pulley...like new!
I know it might sound pretty stupid to do this with 44,000 miles on the car -- but the ride just wasn't like it was when the car was new so I decided to replace everything. Front and rear dampers, control arm bushings, upper and lower ball joints for the suspension...and a 3lb pulley, high flow cats + new oxygen sensors and caldoofy intake elbow. Wow what a difference! The cats and elbow made a HUGE noticeable difference. My check engine light was on for about 8000 miles with a PO420 cat code so I'm guessing theyve been messed up for a while and restricting power like crazy.
ALSO -- for the cats I used the OBD2 type spun converters..something like 9966HM for the part number. They fit perfectly. The tone is not raspy but way more throaty and european sounding. Should have did this years ago!
Old Aug 10, 2014 | 05:36 PM
08Z06's Avatar
Old Aug 10, 2014 | 11:53 PM
Robinb's Avatar
I can see you're pleased with the pulley/cats/elbow. Was there any really noticeable difference in the ride?
Old Aug 11, 2014 | 01:17 AM
08Z06's Avatar
Bigtime for sure. The car rides like brand new now...no more sloppy steering or soft floaty feeling at high speeds. I think my situation is unique though because I've hit potholes at 120+mph and bent a control arm, cracked a wheel in half and tore up a hub assembly. That probably ruined the shocks too..and it was over a year ago
Old Aug 11, 2014 | 09:20 AM
dshirley85's Avatar
I hate to ask, but could you give a ballpark figure of how much the suspension re-do cost you? I'm preparing to do mine, but I'm not sure how much to budget.
Old Aug 11, 2014 | 01:14 PM
08Z06's Avatar
Just for the parts was $4,600. Did most of the labor myself.
Old Oct 14, 2025 | 11:31 PM
MDZJaguarSTR's Avatar
did you tune the ECU? Did the new Cats give you a CEL?
BrentGardner
29
Dec 16, 2024 12:13 AM
AdeV73
Sep 21, 2015 10:29 PM
johanasu
Sep 3, 2015 12:39 PM
Johncy2000
Sep 1, 2015 11:16 AM
Zues
Aug 31, 2015 03:53 PM
