Resolved? Maybe not... P0308/P1314 trouble codes w Restricted performanc
One evening when beginning a ride home I received a flashing yellow engine light with a “Restricted Performance” trouble light. I wasn’t far from home so I got myself there and parked the car. OBDII showed codes P0308 (misfire cylinder 8) and P1314 (catalytic damage). So I let her sit and drove my other car until I could get her right. Research here and online indicated the most likely issue was either coil packs or spark plugs. “Misfire” could be several things and “Catalytic Damage” meant raw gasoline was detected passing into the converter (so probably potential for damage if I kept driving her, but I parked her. So I think we are good). Found these videos by Vance and followed them to replace the plugs and the coil packs. Part 1 Actually not that hard really. If you throw these codes, and are kind’ve handy, I say use the video and go for it. You might have the same luck I did. I just hit 90k miles. Plugs were obviously the original set (bought the car used). Replacement of all plugs (Bosch Iridium) and coil packs (Spectra Premium from Rock Auto) resolved the slight wobble-idle that seemed to come and go on occasion. I cleared the codes and they have not returned. She runs like a beast again. Note: Found a bit of oil in about 6/8 plug wells, but not enough to go replacing gaskets just yet. None seemed to be below the threads and the car doesn’t smoke at all (except for a few seconds after the job. A little Oil from the well dripped into the cylinder through the spark plug opening during the change. This was quickly burned off during first post-job start and she was back to normal exhaust in a few seconds). A conversation with my awesome mechanic confirmed no critical need regarding the minimal oil in the plug wells, and a high five for knowing not to use anti-seize on the plugs lol Many thanks to Vance for the great video! |
Maybe not resolved
Drove to work two days ago, back home, then yesterday across town and stayed the night. Woke up this morning to a request for my keys to move my car. Someone was blocked in and needed out. Handed over keys, they moved the car and returned the keys. No problem. Woke up later and went to leave. Battery was dead. Sigh. Asked and the car started and ran fine this morning during the move. I got a jump and she started right up. All seemed well. But on the way home upon highway first acceleration I felt the misfire and got a flashing yellow engine light. No codes, but misfired all the way home with the same flashing engine light when I accelerated using higher rpm. Obviously a power loss, and wobble idle at stop lights. Considering the above post, And the perfect running after the fix, I’m thinking the coils and spark plugs are not the issue. Thoughts: 1. Someone probably left my door partially open and drained my battery. Could the battery cause this? 2. Wiring on coil plugs was “crunchy” when I manipulated them during the coil change. Could wires at coil connection be the problem? 3. There was some oil found in several of the spark plug wells, and the new coils were slightly shorter than the old ones. Could this allow oil to get in there and cause a misfire? Anyone have any thoughts? Thanks, and happy new year! |
Originally Posted by Reklaw1973
(Post 2007931)
1. Someone probably left my door partially open and drained my battery. Could the battery cause this? 3. There was some oil found in several of the spark plug wells, and the new coils were slightly shorter than the old ones. Could this allow oil to get in there and cause a misfire? These cars are VERY sensitive to battery voltage. If the battery was run down enough so the car wouldn't start by itself, the battery needs to be fully recharged before doing anything else. A jumpstart and a little bit of driving won't properly recharge the battery. Do it right and hook it up overnight on an automatic charger with at least a 10 amp output. A trickle charger won't cut it. If you don't have a charger, then beg, borrow, or steal one. Once the battery is fully charged, clear the codes and see what happens. I suspect the misfire was caused by low voltage as the poor alternator tried furiously to recharge the dead battery. Low voltage = weak spark. |
I had my suspicions
I have heard many times these cars are super sensitive to battery problems. This battery is not that old, and the car sat in chilly weather for a week before the coil/plug fix. She needed a jump at that point, and in my assuming all was well I likely never really got the battery fully charged again. I will happily try recharging first. Almost picked up a charger with only 8amps, but caught my mistake and purchased a charger/jump unit that has 10amp charging. Connected it to the batters and the meter initially showed 50% charge, then over about a min the meter went up to about 70-75% before stopping. The battery is now charging, will advise. Thanks! |
(Post 2007945)
I will happily try recharging first. Thanks for humoring me. No guarantee the low battery charge is the root cause, but it's something simple that needs to be ruled out first. Almost forgot, you had mentioned some oil in the spark plug wells. Did you clean that out before reinstalling the coils? If it's just a little bit of oil, you're probably okay to keep an eye on it after cleaning. If you've got a lot of oil, you'll need to replace the valve cover seals. Make sure you clean inside the boots of the coils, too. Electronic spray cleaner (NOT brake cleaner) works well. |
The saga continues
Per suggestion, I purchased an appropriate battery charger and after several hours the battery was showing full charge. Started her up and immediately the misfire was present. After idle warmup I received two codes: P0301 (Misfire cyl1) and P0316 (Misfire detected at startup). Assuming the car damage code would soon follow I shut her off. Reconnected the bat charger (why not) and the battery showed 50% charge. Set charger to recharge, and began research. My thoughts: 1. Will check wiring for coil pack, looking for wiring/connection problem. Diagnosis by swapping known good parts, etc. Hopefully the code will follow me around and reveal the problem item. 2. Will check spark plug well for oil, and will clean out as needed. (I actually did not clean the wells out when I changed the plugs. Mistake noted lol) 3. Previous “misfire” was cyl 8, now cyl 1. These are consecutive in the firing order, and the sensor looks for power pulses on the driveshaft. That can’t be easy lol... So perhaps this is the same problem manifesting with two different codes? Will advise. Any thoughts or advice is always appreciated, so let me know what you think. Thanks! |
(Post 2008046)
After idle warmup I received two codes: P0301 (Misfire cyl1) and P0316 (Misfire detected at startup). Was that second code P1316 instead? I'm not seeing any P0316 in any of the OBD reference documents: JagRepair.com - Jaguar Repair Information Resource What year is your car? I want to make sure we are looking at the correct document. Also, don't trust any generic code definitions your scanner may show, such as "misfire detected at startup". Always go with the Jaguar-specific definition for the numeric code. I think you are on the right track. Definitely clean up the oil from the spark plug wells and on the coil boots. That alone will cause a misfire from a perfectly good plug or coil.
(Post 2008046)
In response
Yes the code was P1316, I mistyped p0316. Apologies. My car is 2003 S-Type R 4.2L V8 (Supercharged). I will get my multimeter and advise regarding the running post-startup voltage, however this will hold secondary priority to cleaning up the oil that may be present and checking the wiring for loose coil plugs or cracked insulation. The gaskets obviously needs changed because there is oil present in the wells. So that is on the to-do list, waiting on warmer weather. It’s cooold here and I have no garage :/ Also in the shopping cart is the i930 OBD scanner tool. |
(Post 2008322)
I will get my multimeter and advise regarding the running post-startup voltage, however this will hold secondary priority to cleaning up the oil that may be present and checking the wiring for loose coil plugs or cracked insulation. It's easy enough to check and won't cost a dime. While cleaning the plug wells, swap a known good spark plug (cylinders 2-7) with the suspect #1 plug. Keep track of where you install that suspect plug. Do the same with a known good coil, but taken from a different cylinder than the donor plug. Then if #1 behaves itself, one of the other cylinders will act up because it now has the defective part. From the new fault location, you'd then know if it was the coil or plug. See how easy that was, and free! |
Back in the saddle
It was warmer today, so... update: Pulled and swapped coils cyl 1-2, Read codes: p0300, p1316 Pulled coils off 1-2, pulled plugs from 1-2. Paid special attn to ensure I kept track of which item came from which cyl. Plugs may not have been tightened properly, as there was a little oil in the wells, oil on the treads and the plugs seemed to break loose easily when I removed them. My thoughts right then: maybe caused compression problem.
P0303, P1316. 🤦🏻*♂️ Removed coil and plug from cyl 3, plug came loose easily, oil in well and on threads. Cleaned, replaced, tightening etc. Removed coil from cyl 4, ensured plug was tight, reassembled cyl 4. P0303, p1316 Slightly rough idle, obviously still a misfire happening. Hmm... Decided to start testing things by unplugging coil packs while the engine was running. When I unplugged: Coil 3- marked negative change in idle. Plugging back in resolved marked change. Despite the code, this cyl was working. Coil 2- No change in existing rough idle. This Appeared to be the misfiring cyl. Coil 1- marked negative change in idle. Looks like cyl 2 is the misfire, and if you remember... I had switched the coil/plug combo from cyl 1 and 2. So this misfiring assembly was originally from cyl 1, where this trouble all started. Swapped coils only between cyl 1-2 and now the plug-test showed cyl 1 was the misfire. The newly purchased and installed cyl 1 coil was bad. Looks like someone may have been right about my new coil pack being defective. High five! Picked up a new coil, installed it, cleared codes and started the car. P1000 but smooth idle. Test drive went well, including highway run that reached 5500+ rpm and 100+ mph. No engine light. Returned home, scanned for codes: P1000, p456. (Oh you Asshole lol) Fidget With has cap, cleared codes. Restart. Pesky p1000. Smooth Idle. So now, I’m considering her fixed unless and until she throws me a code or a symptom I can address :) To humor a friend... I Tested running voltage at battery: 13.84v She sat for a week in the chilly weather, so when I started this job she wouldn’t turn over. I put the 10amp charger on her and charged while I was working. In the end the battery was fully charged and starting her multiple times without driving when I was doing the diagnostic work on the coil packs. So I feel like the battery is fine, and the running voltage I checked seems ok. Occam‘s razor would say the battery was dead before bc my lady friend didn’t get a door closed properly when she moved the car that morning. But we shall see if anything develops. Thank you all for your input and help. I hope I can contribute to this forum in the future, as you all have :) |
Not sure if you knew or not but P1000 is what you get after clearing all the codes. It means your readiness monitors are not all set and when they are you will find P1111.
You will always have either P1000 or P1111 codes even if nothing is wrong with the car. . . . |
That 13.8 is a test of the alternator - doesn't say anything about the battery.
Keep an eye on the P1000 and if you don't get P1111 fairly soon go troubleshooting. |
Yeah, I knew I was looking for the p1111. So that’s why I’m calling the p1000 pesky. Because I don’t know where to start looking for the problem stopping the OBD Systems Readiness Test From completing. Let’s just hope the p1111 shows up and that bridge doesn’t need crossed :) |
Which monitors are not set?
Still working on getting the better code reader. Meanwhile, replacing the faulty coil seems to only be a temporary fix. Sitting in line at the car wash this evening, she suddenly started that familiar misfire wobble. No codes. But I knew better. Drove home immediately and P0302. P1316. Seriously?!? Tried the “unplug the coil” test to see if I could confirm it was cyl 2 but everything seemed to manifest the desired obvious negative change in idle. When unplugged, nothing remained unchanged to indicate a definite cyl diagnosis. Swapped suspect cyl 2 coil with cyl 1 coil: P0302, P1316 Removed cyl1-2 coils and plugs. Put coils back but swapped plugs: P0302, P1316 Un-plug test and still can’t be sure. Both spark plugs were in tight and came out clean, looking like twins. Maybe one drop of oil in cyl 1 plug well. Plug/clips for coils did not show any signs of split wires or fouling. My thoughts: 1. Injector? While the P1316 code implies raw fuel moving through the converter, Not 15 min before the problem developed I filled up the tank from almost empty with premium from a Kroger gas station. Could mediocre gas in 32 degree weather clog an injector that wasn’t cared for too well by a previous owner? How do I diagnose a fuel injector? 2. Please don’t tell me I threw a piston ring on cyl 2. |
(Post 2013529)
How do I diagnose a fuel injector? First thing, check the pressure at the fuel rail. Use a mechanical gauge, versus just relying on what the scanner thinks is there. After that, for a suspect injector narrowed down to one cylinder: Swap the suspect injector with one from a known-good cylinder. Don't make any other changes at the same time. See if the fault follows the suspect injector. If so, the injector is bad. If the fault stays at the same cylinder, and you've already swapped the plug and coil with known-good components, it's probably time for a compression test. |
Also note how fast the fuel pressure declines after shutting the engine down. The car should hold fuel pressure over night at least.
With a leaky injector you will lose fuel pressure much faster. Let us know what you find? . . . |
Will do. Any videos out there showing what I need to do to access the fuel rail and the injectors? I don’t want to just start taking stuff apart if there is some decent reference material on doing the job. I checked with the local auto parts store and they have loaner tools including a fuel injector tester and the fuel rail pressure gauge. Looking to get into it :) |
On the S Type you have a fuel pressure test port that the fuel pressure tester screws into. You can borrow a fuel pressure tester from the auto parts store. You might have some trouble getting the tester attached and there are adapters. It's been so long since I checked mine but I think the gauge just screwed on?
Check out this thread and the test port is on the passenger side at the rear on the V-8's. I forgot your car details so not sure what engine you have? They have some diagrams in that thread to guide where to look on the 4.2L SC engine. Fuel Pressure Sensor . . . |
Hello!
It got very cold and snowy here, and with no garage I decided it was best to drive my truck while the weather was... anti-Jag? lol We all know our older Jags don't like the cold snowy wet weather, and I don't enjoy DIY mechanic in a freezing snow storm! So I am on pause. However the weather warmed up for a day and I got the itch :) SO I started looking for some detailed info about the process by which I gain access to the fuel injectors. With no real luck. Even bought what I thought was an electronic Chilton manual for my car, that turned out to be a scam basically. So my bank is stopping the $30 charge lol With all that being said I realize there is more work to get the injectors out vs the coils. and with fuel involved I was really hoping to have some more specific reference material wo help guide me through the process before I got under there and started guessing about what has to be removed. Any good videos or reference info about the process out there? |
