s type cooling system refill
Put a radiator in my 2001 S type, can't get the system refilled. have opened both bleed screws but just won't fill. Need some advice.
RE: s type cooling system refill
usually a good vacuum pump or pressure bleeder works perfect..but if you dont have any.. you can let it sit over night or you can close everything except the rad cap .. and cover it with your palm.. (engine off ). and with the other hand squeeze the top rad hose.. couple times then release other hand.. to let air out.. may take several times .. after about 10 minutes shud be good..
