S type fuse diagram
Does any one have a fuse lay out for a S Type Jaguar 4.2 V8 2001 MODEL the windscren wipers have stopped working suddenly I suspect its a fuse but do not have a fuse diagram.
james, check fuse #20 (10 amp) in the primary fuse box and also fuse #29 (5 amp) in the primary fuse box. Both of these feed power to the wipers. You will also need to check fuse #8 (10 amp) in the rear distribution box. The cover should show you where each of these fuses are based on number. If you need more help, I will give you a detailed location of where each of these fuses are located.
