S type problematic.
Is anyone else's S type a big POS that never seems to be fixed? Fix one thing and immediately something else goes wrong. I worked on it for a couple days. Fixed some lights, replaced both left window regulators, replaced the light switch in the trunk, now...no start. Cranks and cranks and nothing. not even trying. Tried flood mode(throttle to floor) not even sure it has it, still nothing. I don't have any diagnostic tools other than DVOM and a code reader (basic). BTW...it ran fine (or at least okay) a few days ago. I'm at my wits end with this car. I can't even take it somewhere and leave the key in it...it wont bloody start for someone to steal it. Sorry for the rant...just needed to vent a bit. Any ideas??
I feel you my friend. I guess the first thing would be a scanner where you can read triggers and fuel rail pressure and the like. Check out the icarsoft stuff. I have the i930 and love it. Keeps my snapon solus in the case pretty much and they are under 200 dollars and model specific so it accesses all modules. Best of luck
Originally Posted by scottjh9
(Post 1968575)
Originally Posted by king of the world
(Post 1968568)
What is your typical driving pattern? I have a 52 mile round trip to work, almost all freeway. Short stop/go trips, by contrast, are much tougher on a vehicle.
(Post 1968568)
What is the PATS light doing? That's the indicator for the security system, a red light at the base of the windshield. I forget the exact details, but the light should flash in a certain sequence before start to say all is good. If the security system is tripped, under some circumstances, it will let the engine crank and crank but not actually start. If tripped, the light will flash a different sequence to tell you specific security issues. |
Maybe the fuel cutoff being tripped or malfuction
Originally Posted by kr98664
(Post 1968579)
Au contraire! My '02 has been phenomenally reliable. It's my daily driver, just coming up on 300k miles. Only left me stranded once in ten years, when the water pump bearing failed. Even then, she was kind enough to break down in my driveway.
What is your typical driving pattern? I have a 52 mile round trip to work, almost all freeway. Short stop/go trips, by contrast, are much tougher on a vehicle. . What is the PATS light doing? That's the indicator for the security system, a red light at the base of the windshield. I forget the exact details, but the light should flash in a certain sequence before start to say all is good. If the security system is tripped, under some circumstances, it will let the engine crank and crank but not actually start. If tripped, the light will flash a different sequence to tell you specific security issues. |
I have a pdf manual also. About 5000 pages i believe. If you have the same one it is very thourough. There will be more members seeing this thread so a lot more good advice will be coming.
(Post 1968568)
Originally Posted by JagV8
(Post 1968605)
No, but I may have a very different car - you failed to give your car details!
(Post 1968684)
oh sorry. 2000 S Type 3.0L
The Duratec engine is quite robust, but it needs basic maintenance to be reliable. |
A 2000 luxury car can be a bargain or money pit. More likely a money pit unless you're expecting to do plenty of fixing etc and can DIY.
There's a "no start" guide if you look, probably in the Stickies. The good news is these cars are not inherently problematic or at 18 yrs old not more than other luxury cars. |
Originally Posted by NBCat
(Post 1968733)
Let's begin with the basics:
The Duratec engine is quite robust, but it needs basic maintenance to be reliable. Thank you for the information. I gives me places to look. I have a scanner coming soon so that should help. |
(Post 1968684)
I once changed the front ball joint, took it for a spin and had an ABS fault, I spent ages checking what I had done before eventually discovering one of the rear sensors had failed. I changed the drivers door locking mechanism and the clutch went the next day. I bought a 2002 face lift S-Type R and ran that from 2007-2010 and did a lot more miles and had very little trouble with it. |
I do not know much about the 3.0l but can you here the fuel pump prime when you turn the key to the run position. If you have a schrader valve in the fuel line you can turn the key to run for a few seconds then off and dpress the needle on the valve easy and see if any fuel comes out. Otherwise read up on the scanner you bought and when you get it you will be more than ready. What scanner did you end up buying by the way
(Post 1968837)
Originally Posted by Homersimpson
(Post 1968807)
Sadly I suspect this is your problem as its one of the early MK1 versions, I had a 1999 S-Type 3.0 from 2004-2007 and it was the biggest pile of turd ever, every time I looked at something went wrong on it.
On the homepage of this forum there is a sticky for owners manuals. See if yours is there and if so it will have fuse/relay locations and that will give you a start for fuel pump circiuts to check. I just hooked in my i930 and when i turn the key on it reads the rail pressure. Look in your pdf manual that you have under the powertrain heading and will find a troubleshooter for crank but no start and it will walk you thru checks. Most of it is using a dvom which you have. I know your pain chasing gremlins. Also search the forum for the jtis download if you have not done so. I do not know the link. Sorry
(Post 1968845)
I bought the scanner you recommended. $153 CAD on eBay. reviews were all real good. Not sure on the fuel pump. There is a faint high pitch whine KOEO from under the hood but it doesn't sound like a fuel pump and there is no pressure at the Schrader valve.
My dad had a Ford Sierra back in the 90's and it had the inertia switch in the centre of the spare wheel. I put the spare wheel in a bit hard after having it out to check the tyre pressure and it knocked it off. Took a while to figure that one out but I was only about 14! |
Just re read your original post. You worked on the drivers side windows so maybe the inertia switch got accidently tripped or a wire pulled loose. On my 06 s type the switch is on the driver side footwell. Look there against the panel. There is a cutout for it. Worth a shot. The switch should be covered in the owner and service manual
(Post 1968888)
