Should I buy?
Hey forum. Don't know much about these vehicles. Looking at buying a 2003 S-Type 4.2 V8 with 133,000 miles for $4k. Seller had to replace the computer modules recently. Any advice comments on this are greatly appreciated.
All depends on condition and history. With no details, impossible to say more.
An S-Type that old and with that many miles is overpriced at $4,000 regardless of condition. Do more research and then decide if you want to offer less money....
And of course the question is why did the current owner have to replace the computer modules, and which ones? These car have a very complex control architecture but the "modules" don't regularly need to be replaced.
================================================== Jaguar: Grace, Pace, and Space - Sir William Lyons 2015 JCNA National Slalom Champion Class M Current: '08 Jaguar S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque) Past: '05 X-Type 3.0/auto Jaguar Racing Green |
Gearbox fault.
Originally Posted by Keith Colson
(Post 1542415)
Shopping in the 4K range, you can do better.
It can be any number of things such as a failing coil on one of the cylinders causing a misfire. The PCM and TCM communicate with each other so a poorly performing engine can cause the TCM to put the gearbox in limp mode.
Is the MIL on and are there any DTCs stored in the system? If there are post them here. One other possibility is the battery. A failing or weak battery can cause all sorts of electrical 'faults' with these cars. If the battery does not have 12.2 volts across the terminals with the ignition in the off position, the battery must be replaced. |
Seller didn't change the modules. Found out that wasn't the problem. Trying to find every reason not to buy it. Biggest positive is paying for it in less than a year.
Originally Posted by ControlIssues
(Post 1544740)
Sorry Keith,
I didn't mean to offend you. You had originally asked for advice on should you buy or not, with all advice being appreciated. You later state that you are looking for reasons not to buy, with the biggest positive being able to complete payments on a $4000 car in a year. If overpaying for a car isn't a good reason, overpaying for one with an existing problem should be. Especially if this problem has the potential to be quite expensive. It seems that the seller's story of replaced "modules" may shift better than the car itself. If this advice isn't what supports your predetermined position, then by all means go for it. After all it is "kind of" your money. Good luck, P.T. Barnum |
(Post 1545040)
(Post 1545040)
(Post 1542415)
You could get lucky. But you need a plan for the rather likely case where you don't. |
(Post 1545040)
I guess your car value is about $2500. |
No offense taken.
(Post 1545108)
Sorry Keith,
(Post 1545234)
Just taking off like it's in limp mode. .
Then you need to post an intro in the new members section. https://www.jaguarforums.com/forum/n...-intro-must-5/ |
Re: car price, buy or not buy etc. It has been my, over many years, observation that the expected cost to maintain a car of this type (I daily drive an 03 S type R) is going to run you at the low end $150 to a rather, shouldn't be surprised, higher end of $230+ per month to maintain and keep your car nice. This is of course in addition to what every you're paying for the car.
Btw....I also agree the price is too high for the current market. Two years ago I bought a one owner, dealer maintained, all records since coming off the show room floor 2003 S type R 112K miles with a brand new dealer installed ZF transmission and torque converter for just a 'tad' over 6K. In the two and change years since I've owned (and loved) this STR the repair bills have been almost equal to the purchase price of 6K ish.....and that's with me doing things like head light bulb replacement (you have to take off the front of the car,...literally), new 'ignition coils and plugs', all my own oil changes as well as gas filter changes, new 'J' box (electronic shift mech.) and other things....not big things but things that add up. With $1,200 to $1,400 of the close to 6K or more in maintenace being parts only and DIY labor = to about 5K if it had been in shop repairs you can see it is not cheap to own one of these cars. If you are not a DIY guy, for at least some if not a lot, of your needed maintenance and 'small' repairs and diagnostic's then the cost to maintain is a pretty 'thick ticket' My suggestion is look and find the absolute best example you can with, if not 'all' records then as long a records history as you can. Talk to and get to know the seller and a one owner car is better than a two owner. A two owner is better than a three....etc. Great, great cars.......but not inexpensive to keep nice. Regardless.......wishing you the very best of luck.....!! M.W. L. Current 03 STR Quartz/lt gry Past XK140 DHC |
Recently (April this year) proud owner of a S-Type 4.2 V8 with some tips maybe :icon_wink:
Check exhaust, i had to replace one muffler. Check headlights, drooping seems to be an issue with some Jags. Check transmission, depending on millage ofcourse all transmissions eventually needs oil replacement and ore more (can be expensive) ! Check Cooling, expansian tank seems to be an S issue, they dry out and can cause coolant engine warnings. Check for rust, trunk and front under sideskirts are main spots. Suspension,Breaks, if you hear any noises driving (bad roads) check it, replacing arms etc. also can be expensive. Check if all electrics work, mirrors (softclose), sunroof, windows, etc. etc. And most important check the engine for strange noises etc. etc. if it had decent maintenance it should be ok, the V8 seems pretty "bombproof" and even high millage should not be a problem. New original parts are not cheap ! Lots of good as new parts can be found with some patience and if you are handy enough it saves significant money :) Get an OBDII so you can do the first diagnostics yourself. Sofar i havent had major issues besides the ones i knew from start. Overall with some TLC this V8 4.2 is a lovely car to drive imo and puts a smile on my face if someone thinks he's fast :D https://cimg9.ibsrv.net/gimg/www.jag...c88e6e5c46.jpg |
Very sound advice and a great picture.....cool
