Something had to break eventually- coolant tank
Old Apr 17, 2026 | 04:36 PM
scottjh9's Avatar
Originally Posted by DoubleChevron
the lower hose being a proper hose clamp rather than the crappy plastic clips sells it for me .... I can buy hose by the meter and use some brass fittings and throw those crappy molded hoses away
i agree. But i changed all coolant hoses within the last 4 years so no reason to adapt. That hose going to radiator tank might fit by cutting off palstic connector and shoving clean end on the hose connector. Maybe have to extend it a bit with a hose barb and more hose but that would make it way easier to connect the hose before putting the tank in place. With the plastic connector you are forced to put hose on after tank is in place and hope the little clip stays in place
Old Apr 18, 2026 | 09:22 AM
clubairth1's Avatar
Community Influencer
Ah yes that little clip that likes to shoot off into never never land! Kinda forgot about that one.
scottjh9 I think now you can get that clip separately? Thought I read that somewhere?
Old Apr 18, 2026 | 10:32 AM
scottjh9's Avatar
yes you can get it. I bought a three pack a couple years ago. Cannot remember thread that gave part number
Old Apr 18, 2026 | 10:59 AM
Doug's Avatar
Originally Posted by Doug
These are NLA from Jaguar. I bought a replace from Rock Auto for about $50.
The cost is low and the replacement is easy. Probably not worth the effort of finding or fabricating a longer lasting replacement.
From all that's been said I'll consider the coolant tank to be a consumable going forward. Assuming that the new part is lower quality than the original I'll plan on replacing it again in 5 years or so. I'll order a spare.
FWIW I replaced the tank a couple days ago. The Rock Auto replacement fit fine. We'll see how long it lasts.
Somewhat against my better judgement I also replaced the heater valve. I used the Motorcraft YG378.....hoping that the higher price might mean higher quality. We know it doesn't always work that way. I was hoping replacing the valve would cure the small issue of a slight left side-versus-right side disparity in output temps from the vents when the system was in cooling mode. It didn't. I'll do some reading-up on this issue if I decide to go further.
Anyhow, the task was uneventful and unremarkable. Took about an hour.
I drove my TR6 for a few days while waiting for parts. It was a pleasure getting back into the Jag
Cheers and thanks
Snackalac
Feb 29, 2024 01:23 PM
MattSteele
Sep 2, 2014 11:11 AM
one
May 16, 2014 02:12 PM
Eau223C
Jan 19, 2013 04:39 PM
Jaguarnewbie2011
May 1, 2012 12:33 PM
