str vs monstr z
Old Aug 21, 2011 | 09:34 AM
Staatsof's Avatar
Originally Posted by bfsgross
An example of a very similar Jag motor making big hp: Avos's 600+ hp 4.0 XKR, primarily performed with a twin screw blower.
Very similar to what?
Old Aug 21, 2011 | 10:47 AM
Bacardi 151's Avatar
I think he means the STR engine...Covert the blower to a twin screw gain gobs of hp...
Old Aug 21, 2011 | 12:24 PM
bfsgross's Avatar
You're spot on Bacardi. Though Avos's motor has less displacement (via a shorter stroke) and is less technically advanced as the STR's, it's twin screw blower was worth 200 hp. Aside from high flow cats, his earlier model XKR sports the stock exhaust. Members of the XKR community who placed Avos's TS blower on their 400 hp 4.2's are pushing well over 500 hp. All they had performed were modding the exhaust and bolting on his TS. Avos will complete development of a TS for the STR if he recieved orders. Mafioso is working on a TS too. As mentioned earlier, 500+ hp STR are around the corner.
Old Aug 22, 2011 | 11:34 AM
qwiketz's Avatar
Only 585HP? What did they do to the Ferrari to get that sort of number? That's over 200HP more than stock at the crank.
The 585 was my car. Just trying to show that a little extra power goes a long way with similar car weights. In the op's run weight was also probably a factor as it's really easy to cut out weight of a late 90's z.
Old Aug 22, 2011 | 03:48 PM
The Chris X's Avatar
Qwik is on the money IMHO. Isn't there a ratio rule of thumb type thing that every 100lbs removed frees up approx 10 hp at the wheels? You racing guys probably know what I am talking about. The beauty of the STR is the combination of very good thrust coupled with a compliant ride yet agile handling, with timeless grace and style to go with everyday drive-ability I doubt you will fing anything about style and grace in a description of said "Z" car. That said, they go like stink when properly equipped and there are mods galore that don't require you to kidknap an electronics engineer and a machinist to perform, and a displacement advantage. That said, it is exciting to follow the progress of the STR modders and explore the limits.
Old Aug 22, 2011 | 08:28 PM
bfsgross's Avatar
Well put Chris...couldn't have said it any better.
clubairth1
30
Sep 3, 2025 04:38 PM
Manjag
Oct 1, 2015 05:34 PM
JaguarSV8
Oct 1, 2015 01:58 AM
SoCalJagS
Sep 27, 2015 09:20 AM
