Stripped intake manifold brass fitting
Old Oct 12, 2024 | 12:59 PM
Nutter3nutter's Avatar
Default Stripped intake manifold brass fitting
What's the best way to get the bolt out that stripped the fitting?
number two questing can I replace the brass fitting or do I need to buy a new lower intake manifold?
Old Oct 12, 2024 | 01:01 PM
It's a 2002 s type 3.0 I forgot to post that part.
Old Oct 12, 2024 | 10:09 PM
kr98664's Avatar
Are you talking about the brass inserts in the lower intake manifold? These inserts are for the bolts securing the upper manifold, aka plenum.
If the insert has come loose, can you remove the other bolts and then lift the upper portion straight up? Once the plenum is removed, you’d have good access to grip the loose insert with a pair of pliers.
I suppose you could clean up the threads on the old insert and then epoxy it to the lower manifold. Make sure it does not stick up or you’ll never get a good seal for the plenum. But if there’s any doubt about such a repair, I’d suggest a serviceable used lower manifold. I see several on eBay right now.
Old Oct 15, 2024 | 04:02 PM
Thanks yes it's the brass fitting and the bolt just spins and I think it goes to the lower intake manifold.
James Hawkins
Jan 19, 2021 08:51 AM
felinecat
Mark V - X 420G
Jul 14, 2017 11:35 PM
Gus
Jun 23, 2013 02:06 PM
JagWar
17
Jan 21, 2011 04:20 PM
stevis05
Jan 10, 2010 04:30 PM
