Throttle body problems?
Old 08-31-2018, 07:55 PM
Russell11's Avatar
Default Throttle body problems?
Dear Guys
Can anyone tell me what the problem is with my S Type R? It throws up these dashboard warnings and my code reader shows these problems. Car will only idle and is not drivable. Battery is in good shape. MAS has been cleaned.
Old 08-31-2018, 08:09 PM
Datsports's Avatar
This looks to be the same fault mine had when I purchased my STR .
first check the throttle position sensor plug for water ingress
. and for corroded or bent pins .
Also charge your battery . And hard reboot the car . these cars are fussy about power supply .
if you find water in the TPS plug you will need to carry out the TSB patch and/or silicone the two vents/slots and wire gaskets on the TPS plug as I did . also de-oxidise / clean and coat the pins and plug sockets with electro grease or WD40 . 4.5 years later with mine and no further problems .
mine had the TSB patch fitted , but some idiot had refitted the windscreen cowl screw , in which the TSB says to not refit that screw . as water drops through the white plastic screw thread strait on to the TPS plug .
so i removed the thread also and taped up the strut brace also as a safe guard .
Old 08-31-2018, 09:22 PM
Russell11's Avatar
Thanks. How do I disconnect the TPS plug to look inside it?
Old 08-31-2018, 09:36 PM
Datsports's Avatar
although it is right at the rear of the eng bay , it is accessible . there is a button on the side of the plug .
you basically just press the button and wriggle the plug upwards . and look in there .
Old 08-31-2018, 11:19 PM
kr98664's Avatar
Received 1,984 Likes on 1,401 Posts
Please define "good shape".
These cars, especially 2003+, are very finicky about battery condition. For the parking brake and DSC faults, please see this thread. It's a scorecard of what fixed them. The faults typically appear together:
https://www.jaguarforums.com/forum/s...attery-193787/
A little more history, too, please. Did the P0121, DSC, and park brake faults all appear together? Any recent work done? Has the car been driven regularly or has it sat for a while? What is your typical drive pattern, long or short trips? Your shoe size? Ginger or Maryanne?
Old 09-01-2018, 04:59 AM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
#1 suspect by a mile - battery.
Needs to be about 12.6V after an overnight stand and without starting the car.
Check the rest once the battery is not #1 suspect.
Old 09-01-2018, 05:54 AM
Russell11's Avatar
I tested the battery and it passed with flying colours. All faults appeared simultaneously. Car only purchased two months ago. Has sat in garage for most of those two months.
Old 09-01-2018, 09:17 AM
JagV8's Avatar
That sitting is usually what causes battery problems. Was it on a ctek-type device?
Old 09-01-2018, 10:31 AM
clubairth1's Avatar
Received 2,236 Likes on 1,765 Posts
Change the battery BEFORE you do anything else!
We have seen this countless times before. Especially if the car has been sitting.
Please erase all codes and make sure they come back.
Let us know what the fix was if you can?
Old 09-01-2018, 10:34 AM
kr98664's Avatar
As JagV8 asked, have you put the battery on a charger? Sorry to keep beating a dead horse, but what exactly did you do to test the battery? We've had many examples on the forum of batteries that show good with most load testers, but still let the voltage drop below a critical level during start. The general rule is you want to see at least 12.6V present BEFORE start. Below that, things get wonky. DSC and cruise control faults are the most common problems. 12.6V is quite high for a battery at rest, well above what most testers will call good.
If hesitant to throw a battery at it, and I don't blame you, try this: Put an automatic charger on the battery, at least overnight. Use something with at least 10A output, NOT a trickle charger. Keep the charger connected while you start the car and see if the faults clear. If so, low battery voltage was the culprit.
Old 09-02-2018, 04:19 AM
Russell11's Avatar
I checked the battery with a $20 battery tester. Said it was “excellent”.
Old 09-02-2018, 10:01 AM
JagV8's Avatar
Sadly if you're sure, every other fix is liable to cost more and may be tough to figure out.
Old 09-03-2018, 07:27 AM
kr98664's Avatar
Was this a capacitance type tester? It's much higher tech than my trusty old resistive tester (aka toaster) but is also more finicky. I've had it tell me the same battery is.anywhere from 40 - 80% healthy, tested only minutes apart. Also, the "excellent" label was probably from the marketing department. The engineer who designed the tester probably wanted something like "No glaringly obvious faults at the moment". All I'm getting at is the results may not be 100% conclusive, so don't fall into that trap. My tester has an option to check with the battery installed or disconnected. If your tester has that option, the latter is much more accurate.
Have you fully.charged the battery and left the charger connected during engine start? If the car now.behaves, low prestart voltage was the problem. Won't cost a cent to try. If you don't have a charger, we will wait while you get one. For any electrical troubleshooting, rule #1 is always begin with a fully charged battery. I can't stress strongly enough how important that is.
Also, have you checked yet for water at the TPS connector, as previously suggested? Search the forum for P0121 and you will see many hits about water at the plug.
Old 09-06-2018, 02:57 AM
Russell11's Avatar
Dear Guys,
By way of an update, here goes:
Bought new battery, installed it, engine started first time and revved nicely when accelerator pedal pushed, all codes erased and dash warning lights went out bar an apply handbrake warning. New battery appears to have sorted out the major problems. THANK YOU VERY MUCH.
Does anyone know what’s going on with the apply handbrake light?
The following 3 users liked this post by Russell11:
Datsports (09-06-2018), JagV8 (09-06-2018), kr98664 (09-06-2018)
Old 09-06-2018, 03:10 AM
JagV8's Avatar
Thanks for the update.
The idea is to recalibrate (re-teach) the EPB's module's knowledge of the brake position.
Old 09-06-2018, 03:15 AM
wydopnthrtl's Avatar
There are a number of resets to do when a battery has been disconnected. Try those first (in sticky area)
Old 09-06-2018, 06:16 AM
Russell11's Avatar
Forgive my ignorance, but what is the sticky area?
Old 09-06-2018, 10:18 AM
clubairth1's Avatar
It's the threads that stay at the top of the forum all the time. These are considered our "All Time Greatest Hits".
Look there to get a free copy of the shop manual too! (Called the JTIS)
But it's a great feeling to find such a complete and pretty cheap repair!
This forum has saved me thousands of dollars and it's a fun hobby too!
Old 09-07-2018, 06:38 AM
Russell11's Avatar
The forum has reinvigorated my interest. A big thanks to everyone who helped. I think I need to take a more positive approach when something goes wrong on the Jag. I tend to fear the worst.
Old 09-07-2018, 10:31 AM
kr98664's Avatar
Glad it all worked out well for you.
Can we please get more details of your battery tester, such as brand and model? Did it have options for testing the battery in or out of the vehicle? In other words, connected or disconnected. My hunch is the easier connected option has too many variables to be accurate.
Quick Reply: Throttle body problems?
