Valve on top of radiator reservoir: Why is it leaking?
Old Feb 10, 2015 | 09:41 PM
BKSinAZ's Avatar
Default Valve on top of radiator reservoir: Why is it leaking?
2005 S-Type V6 3.0
What is the valve/screw on top of the radiator reservoir. Why is it leaking, did I over fill the reservoir? If it is defective, how can I stop it from leaking? I've tightened it down slightly, but it still leaks. Is there a rubber seal/gasket that is replaceable?
Also, if I have to buy a new reservoir, what is the best after market brand and where can it be purchased from?
thanks in advance
Bryan
Tucson Arizona
Old Feb 11, 2015 | 03:48 AM
Paul792's Avatar
Here are 2 links to new expansion tanks. The first one OEM.
Amazon.com: Jaguar OEM S-Type and XJ Coolant Expansion Tank: Automotive Amazon.com: Jaguar OEM S-Type and XJ Coolant Expansion Tank: Automotive
03 2003 Jaguar S Type Expansion Tank - Cooling System - Eurospares, Genuine, Meyle - PartsGeek
This is a link for tips for replacing it from forum members with some great advice and photos in their discussion.
https://www.jaguarforums.com/forum/s...lacment-52090/
Old Feb 11, 2015 | 06:45 AM
It's the bleed screw, I don't know if it has a seal or a seat, It's never been a problem with leaking for me.
I think it comes right out so you could check / clean it and see what's up.
I'd stick with an OEM tank if I had to choose.
Old Feb 11, 2015 | 11:37 AM
Jimmy 68's Avatar
I was told there is an o ring under that bleed screw.
It also should not be overtightened, just snugged.
Old Feb 11, 2015 | 11:57 AM
tbird6's Avatar
Wait until the car is cold. Remove the bleeder screw and inspect. There is an O-ring so it might be damaged or missing. Of course you could have a crack in the plastic that makes it look like the bleeder screw is the problem.
You probably know the upper plastic tanks are a known problem area so you might consider changing the entire tank if you plan to keep the car.
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
Rivguy
Dec 4, 2020 07:55 AM
sogood
Sep 15, 2015 07:35 AM
