Where can I buy a new relay
I need a XR83-14B192-BA relay. When I do a search for the part, I can only find adds for USED REAYS. Where can I buy a NEW RELAY.
hak,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to S-Type section. Members here with the same model as you have will know where to source the relay. The Advice/ Feedback section is for posts about the forum and NOT for technical questions. Graham |
Not the cheapest I guess but dealers will have them.
Your car is a twin to the Lincoln LS. Any Ford dealer will have or can get the relay. Probably better if you know where it goes but most of the relays are all the same. Can you swap yours around to make sure it's bad?
Relays are not failure prone? . . . |
Thanks for your advice on the Ford Dealer. I did swap the one relay I thought was a problem with another and the swap confirmed the relay was bad. Thanks again for your help.
