Non ABS for 'The Ice Princess'
Old 08-18-2017, 06:39 AM
orangeblossom's Avatar
Received 3,740 Likes on 2,593 Posts
Default Non ABS for 'The Ice Princess'
Having now got 'Cherry Blossom' and '50 Shades' my Grey XJS back on the road again, I have now got another one in need of Restoration.
Which is called 'The Ice Princess' that hasn't been on the road since 2003.
Lots of Problems with this one, including fitting a New ABS Valve Block, which I picked up at an Auto Jumble for only £50!
But since the Master Cylinder Actuator is out of the Car, I am seriously toying with the idea of going Non ABS.
Where instead I would fit a Brake Booster.
When I learned to drive many years ago, it was on a Car without ABS and since my Merc also has a Non ABS System.
Maybe its just me but I prefer it, as its such a simple system that has a great Brake Pedal feel, of really being there. (if you know what I mean)
So what better time to try that out than now.
But in the event it doesn't work out and I find that I don't like it in this Car, then it would be very easy to Swap it back over.
There is a Chance I may already have the 'Kit' I need, as I have a Scrap Mercedes 190d that already has the Brake Booster System.
So with a bit of modding, I can swap the Pedal over (I've also got a spare pedal for an XJS)
Maybe not a piece of Cake to do this, as already there could be a Problem, as the Scrap Merc 190d has got a Manual Gearbox.
Which means that this Brake Booster has a pipe leading off it onto the Clutch.
Could I just Block this Pipe off?
As this Brake Booster is in good condition and already has a Master Cylinder fitted.
Which altogether could save over £200.
Ideas/Suggestions Please.
There will be a Photo of 'The Ice Princess' on my 'Cherry Blossom' restoration thread.
Brake Booster System from a Mercedes 190d
which also has a pipe coming off for the Clutch
but could I 'Mod it' to fit 'The Ice Princess'
Old 08-18-2017, 08:50 AM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
You want to fit the brake booster AND master cylinder from a Merc to an XJ-S? Master cylinder doesn't equal master cylinder. And don't forget: you'll be needing to replace a lot of pipes to connect a normal master cylinder from an XJ-S without ABS to one formerly with ABS.
Old 08-18-2017, 12:06 PM
Hi Daim
Don't get what you mean: Master cylinder doesn't equal master cylinder.
Pipes no problem, I can make those but Greg is probably right, either use all Jaguar Parts or keep the ABS.
Old 08-18-2017, 12:36 PM
Daim's Avatar
Not all master brake cylinders are the same. Connections, threads for pipes, etc., all differ. Also if ATE, Girling, Bosch, Delphi, blub... Every one sits different. And then for the XJ-S rather important: 3, 4, 5 or 6 pipes The XJ-S needs 3. I think most Mercs had 4 (brake pressure balance for the rear brakes was achieved in the brake cylinder rather than in a little unit at the rear, like in the XJ-S)
I personally(!) would never fit a different master cylinder than the ones originally used. They can cause really big PITA problems.
The following 2 users liked this post by Daim:
Grant Francis (08-20-2017), orangeblossom (08-18-2017)
Old 08-18-2017, 02:31 PM
icsamerica's Avatar
Received 1,359 Likes on 790 Posts
Just use the vacuum booster from an early non-abs car the whole pedal assembly will bolt right in. If you still want abs you can use the add-on system from Bosch that Jaguar used in the xj40.
Old 08-18-2017, 05:56 PM
Hi Daim
Cheers! That makes sense.
Old 08-18-2017, 06:09 PM
ptjs1's Avatar
Received 2,935 Likes on 1,956 Posts
Hi OB,
I really do understand why you might want to do this, but I just wouldn't! Even if you fit a completley original Jaguar XJS setup (I wouldn't do it any other way) you're going to have a fight on your hands every time you MoT it to prove to the tester that it has no components anywhere in the car relating to the ABS that they expect it to have. And you'll probably never be able to sell the car in the future for reasonable money because of the unexpected brake system.
You're developing a reasonable expertise in the ABS system so I'm sure you're more than competent to sort out any ABS problem that the Ice Princess might throw at you!
Just my view, with your absolute prerogative to completely ignore it!!
Paul
The following 2 users liked this post by ptjs1:
Grant Francis (08-20-2017), orangeblossom (08-19-2017)
Old 08-18-2017, 06:14 PM
Hi icsamerica
One of my first XJS's was non ABS and what I remember about it most, was the way that it could be relied upon to Stop you, no matter what.
What I also remember about my ABS Cars, was the way the ABS nearly killed me when one of the ribbon connectors inside the Valve Block broke.
And very nearly Spun me off the Road.
So being that I was able to find a Non ABS System, I would like to Retro-Fit it in this Car, except that no Car Breakers Yards has got one.
From time to time they do come up on ebay but some of them look in pretty rough condition.
Old 08-19-2017, 02:59 AM
Greg in France's Avatar
Received 9,077 Likes on 5,345 Posts
OB
Talk to Andy Harvey at Just XJS. You only need the servo second hand, the vac reservoir and the vacuum pipework, but you really must buy a new M/C.
Greg
Old 08-19-2017, 03:41 AM
xjsv12's Avatar
What do you think about from Celebration XJS? Pedal, housing, servo, m cylinder, reservoir and "little " work. That is what you need.
Old 08-19-2017, 04:33 PM
Hi Paul
You are probably right but if I could find the right piece of Kit, then I would like to do it anyway , so I can make a Comparison with my other Cars.
Old 08-19-2017, 04:42 PM
Hi xjsv12
Many thanks for the drawing
(I've been trying to find this photo)
If I disconnected the Pedal where those 4 Bolts are, would I be able to bolt that part straight onto a Vacuum Servo Brake Booster.
The Photo is of my New ABS Master Cylinder Actuator but I have got an Old one that I could use instead.
XJS V12 Master Cylinder/Actuator
If I undid the 4 Bolts in the Photo, would a Brake Booster Servo bolt on in its place.
Old 08-19-2017, 04:43 PM
Hi Greg
Cheers!
I'll have a word with Andy
Old 08-20-2017, 02:18 AM
The servo bolts straight up to the four holes on that pedal box Alex. No spacer required. This diagram (albeit LHD) shows the vac system parts you need from Andy.
orangeblossom (08-20-2017)
Old 08-20-2017, 03:35 AM
Hi Greg
Cheers!
It looks like I am halfway there already, that Pedal bit on its own must be quite expensive (very)
I've seen some Brand New Brake Boosters on ebay for an XJS Circa: £100
So would make sense to Start with a New One, in case the diaphragm is leaking.
But what would I do about a Reservoir?
Could I just make something up?
Old 08-20-2017, 04:56 AM
ptjs1's Avatar
OB,
Reservoir kit is £80 new still available from Jaguar.
Paul
Old 08-20-2017, 07:07 AM
Originally Posted by ptjs1
OB,
Paul
Hi Paul
That's Handy
Cheers!
But do I still need a Vacuum Tank, as there isn't one on my Non ABS Merc.
Old 08-20-2017, 07:11 AM
Daim's Avatar
OB, always remember: sod engines and trannies. DON'T be a cheapskate when it comes to brakes and tires. They are the ONLY things which make the car stop. DON'T (please!) just bodge something together to make it work somehow... And if you remove the ABS system, remove the LOT. Not just deactivate... Means removal of wiring, ABS ECU, pump, ABS sensors, ABS rotors (would look suspicious if you have the rotors on the hubs (visible from behind) and no ABS sensors), ...
A lot of work for something, which actually very rarely goes wrong and if it does, is easily serviced and repaired. Please don't get me wrong, BUT this is just one heck of a stupid idea. I personally(!!!) when it comes to brakes DON'T experiment around and play with things. That is especially one of the reasons the German TÜV does NOT allow alterations with ABS systems. If your car had it from factory, it HAS to have it when taken in for inspection. It also has to work (no lights staying on etc.).
You have the new unit which won't be getting better the longer it sits on a shelf. You also have 2 other cars with the same ABS unit (IIRC). Why would you want to stock up on parts for a car without ABS? Kind of like having 4 dogs and then getting a cat. Your shelves are full of dog food but a cat is a good idea at first, until you have to stock up on cat food... And kitty litter. And...
Please give it a think over before you take any action. Just please seriously give it a think over...
Old 08-20-2017, 07:19 AM
Hi Daim
Ok I think it over but my immediate Plan is to get the 'Ice Princess' out of the Garage, so that 'Cherry Blossom' can be under cover over the Winter just for a change.
'The Ice Princess' is the worst of the fleet and what's more I don't even know if the Engine will Start.
Not used since 2003!
Old 08-20-2017, 07:58 AM
Daim's Avatar
If you can turn the engine over by hand, then that is a great start.
