engine removal and rebuild
Old 10-28-2017, 08:51 PM
Belmon's Avatar
Default engine removal and rebuild
Ok starting off from this thread
https://www.jaguarforums.com/forum/x...-190097/page2/
the reason im doing this is because cylinders 1 and 7 have low compression.
1 and 7 have around 30-40 psi. the rest are 115-135.
pulled it in my garage and begun the the removal. didn't get very far today got interrupted and had to stop. all i got off was the air intake and sprayed some penetrating fluid on the cat bolts to help with removal.
Old 10-28-2017, 09:07 PM
Belmon's Avatar
also when i removed the coolant tank it was empty there some coolant in the hose on the bottom of the tank so i might have a leak somewhere. and im guessing that the sensor in the tank is for the low coolant light/level. so that's shot or has a short somewhere.
Old 10-29-2017, 03:41 AM
Sean B's Avatar
Received 1,333 Likes on 1,053 Posts
Before you pull anything else top off the coolant tank and slide the float up and down the shaft inside the tank to see if you get the level sensor back to functioning...
I've posted a few tips and tricks to aid removal in other thread - I'll try and locate it. The main one if pulling the engine out from the top is to keep the trans on the engine, and use a trolley jack on it's tail as you pull the whole thing up and forward out of the car. Also remove the front wheels and drop the front of the car as low as possible.
Old 10-29-2017, 08:57 AM
avern1's Avatar
Received 1,317 Likes on 1,004 Posts
Not to discourage you from a complete rebuild if that's what you want to do, BUT. You might want to pull the heads first and check for dropped valve seats. The engine uses pressed in valve seats and have been known to drop out and cause LOW compression. You may not have anything wrong at all on the bottom end BUT then again you might.
Just a passing thought.
Old 10-29-2017, 09:56 AM
BobRoy's Avatar
+1,Vern.
I was thinking the same thing. Another clue was low on coolant.
Belmon has the car ever overheated. Overheating can cause the valve seats to drop and give you a lower compression reading on those cylinders. As Vern suggested just take the heads off and see if this is what happened. More than likely you problem is in the heads.
IMHO.
Old 10-29-2017, 10:15 AM
Belmon's Avatar
Ok so the car has never over heated when I was driving it the temperature always stayed at the middle of the gauge. Also when I did the timing I replaced the thermostat and the thermostat housing. Also the rear main seal is leaking. If the rear main was not leaking I would just pull the heads and look at the valves.
Old 10-29-2017, 12:49 PM
RJ237's Avatar
Received 2,781 Likes on 2,225 Posts
That's a nikasil block and if it needs relining it's expensive, so I hope it is the valve seats.
Old 10-29-2017, 01:36 PM
BobRoy's Avatar
Thank you for the info. I removed the engine and transmission together on a 98xj8 a year ago. I found the Workshop Manual useful on removing the engine and Engine Course Code 168 for the actual work on the engine.
Best of Luck.
Old 10-29-2017, 03:28 PM
Dutchy's Avatar
sorry for butting in but bobroy where do I get a copy of this Engine Course Code 168 pls
I have a 3.2 98 jag and didn't know the 4.0L had the same sort of liners
thanks dutchy
Old 10-30-2017, 06:57 AM
BobRoy's Avatar
This link is from Gus's site Jagrepair.com
http://www.jagrepair.com/images/Auto...Code%20168.pdf
Belmon (01-13-2018)
Old 10-30-2017, 07:06 AM
popeye68's Avatar
edit : Bob beat me
Old 01-09-2018, 10:47 PM
Belmon's Avatar
Ok so now that the holidays are over and done with I have started the removal process and I’m now just waiting for my engine stand and engine hoist to show up. Also does anybody know the best way to get to the left engine mount bolt? At the time I got to that part it was to dark. That bolt and the hoist/stand are the only thing holding me up right now. Got everything off in about 6 hours.
Old 01-10-2018, 05:50 AM
BobRoy's Avatar
It has been a couple of years but as I recall there is a single bolt or nut under the subframe that you remove. The mounts stay on the engine when you remove it.
Old 01-13-2018, 01:02 PM
Belmon's Avatar
She’s out!
Old 01-13-2018, 01:03 PM
Belmon's Avatar
It was rather easy coming out I was really surprised. I thought it was going to be harder
Old 01-13-2018, 03:29 PM
Belmon's Avatar
It begins
The following 3 users liked this post by Belmon:
BobRoy (01-13-2018), RJ237 (01-13-2018), Tonypybus (01-25-2018)
Old 01-13-2018, 05:30 PM
Belmon's Avatar
My plan now is to get a video camera to record me taking it apart and do a time lapse of the disassembley and reassembley. And so if I get stuck reassembling I can look at the video
Old 01-13-2018, 07:30 PM
BobRoy's Avatar
Do you have the engine repair course code 168
Never mind. I already gave you the link
Belmon (01-13-2018)
Old 01-14-2018, 09:24 AM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
Just a late question: did you check the valve settings and did you do a pressure loss test?
low compression can come from lack of valve settings, as these engines have standard shimed tappets rather than hydro tappets...
Old 01-14-2018, 02:15 PM
Belmon's Avatar
I did a leak down test on on #1 and #7 and they lost pressure. I did that in October. Also I told myself if I’m pulling the valve covers again I’m pulling the engine out to do the rear main seal and to fix other leaks that I cannot see.
Quick Reply: engine removal and rebuild
