Sponsored by: DashLynx
Mina Gallery front grill options
Old 11-16-2017, 12:24 PM
myexcursion's Avatar
Default Mina Gallery front grill options
Want to pickup a new front grill to replace my '07 grill. Looking at going Black since the XK is Indigo Blue w/ Blue top. Are there any other options aside from Mina ? Anyone know if there are any promo codes or discounts ?
Old 11-16-2017, 01:55 PM
BruceTheQuail's Avatar
Received 1,270 Likes on 875 Posts
I bought my grille from Mina. I bought some Adamesh grills for one of my XFs and that was a good experience. Adamesh do XK parts.
Bear in mind that if you replace the OEM plastic grille with a wire one you can see the paint inside the nose cone. That might not be an issue for the indigo blue, but looked silly with my silver XKR, so I had to wrap it inside.
https://www.adamesh.co.uk/body-styling-36-c.asp
myexcursion (11-16-2017)
Old 11-16-2017, 02:18 PM
Thanks. I'll keep that in mind. It looks like the Mina one is pretty simple enough. Pull the old emblem off the existing grill and then lay the new one over it and place then new Mina supplied emblem over. Hopefully not too much showing from behind..
I was also thinking of just taking off the existing winged emblem on my 07 and see if I could replace just the emblem ( leave the existing black grille ) with a new emblem - minus the wings. Anyone know if that's possible or if can purchase just a replacement - maybe an '08 emblem and simply swap that in place of the winged 07 ? same size or not ?
Old 11-16-2017, 04:03 PM
For the '10 model at least Mina stopped selling the grille that you attach to the existing in favour of one where you remove the old grille and replace it. From memory there were issues where people could see the old grille inside the new. That might not be an issue where your existing grille is black (or if it is silver you might be able to spray it with that black rubber stuff first).
Fully replacing the grille is a bit of a production - while Mina say that you can do it without taking the nose cone off, I wasnt able to and ended up having it done by panel beaters.
The Mina grille comes with a nice growler emblem, you can have it red or black.
myexcursion (11-18-2017)
Old 11-16-2017, 08:52 PM
steve_k_xk's Avatar
Received 1,538 Likes on 889 Posts
Wing emblem removed, new growler badge installed along with s badge.
Attached Thumbnails Mina Gallery front grill options-1510200783134.jpg   Mina Gallery front grill options-1510203116866.jpg
myexcursion (11-17-2017)
Old 11-17-2017, 07:55 AM
Looks great ! Is that the Mina grill and does it come with a new growler badge ?
Anyone know if Mina is doing any Black Friday or promo codes ? May be looking at some other items too
Old 11-17-2017, 12:06 PM
steve_k_xk's Avatar
No it's not the mina grill it's the standard xk grill with the wing emblem removed and a black grower badge purchased from eBay.
Old 11-17-2017, 12:35 PM
110reef's Avatar
How do you take the growler off? I have been contemplating replacing my black growler with a red one.
Old 11-17-2017, 06:39 PM
steve_k_xk's Avatar
Reef
The wing emblem is held onto the grille with 8mm bolts that protrude through the rear side of the grille, the original growler is part of the winged assembly .
The trick is to loosen one side of the front bumper in order to get your hand behind the grille to remove the 8mm bolts there should a total of 4.
Torx bits will also be needed to remove the inner guard lining
Old 11-17-2017, 06:42 PM
Cee Jay's Avatar
Received 5,159 Likes on 3,090 Posts
OR, go buy yourself a tiny bottle of Model Paint in the bright red for a buck, then take five minutes painting the black into red. You wont have the serration-looking stuff, but it's not noticeable anyway.
Old 11-17-2017, 06:50 PM
steve_k_xk's Avatar
The other option for those who aren't entirely confident with removing one half of the bumper is to try and go through the top.
If trying to go through the top make surely you wear a long sleeve t shirt to minimize any cuts/grazes on the forearm.
In order to go through the top the radiator shroud will be needed to be removed, also the 10mm bolts and clips holding the front bumper
Attached Thumbnails Mina Gallery front grill options-1510966069758.jpg   Mina Gallery front grill options-1510966100614.jpg
kj07xk (11-17-2017)
Old 11-17-2017, 07:08 PM
Reef
now you got me thinkin... Maybe I should keep my existing black grill and instead try reaching in and removing the existing 07 front growler emblem ( with the wings splitter ) and replace it with a newer growler ( minus the splitter wings ). Is there a direct swap growler or something that fits in its place ? I see a 70mm for the newer models on eBay that might work , just need to see how it attaches and if it covers any exiting holes after removing the existing one.
Old 11-17-2017, 07:20 PM
CleverName's Avatar
For my 07XK, I just bought the OEM wire grill, as it was an optional accessory.
Loved it, and when I got my 2010 Jag had no equivalent, so I bought the Mina Wire version.
Total pain in the **** to install per instructions (Scuffed a lot of paint trying), so I finally went to the local hardware store and created mounting brackets of my own.
Old 11-17-2017, 08:25 PM
steve_k_xk's Avatar
JAGUAR 85mm BLACK GROWLER FRONT GRILLE EMBLEM BADGE ROUNDEL XJ XF XK X-TYPE | eBay
As the new badge has locator pins in a different location, the only modification that will need to take place is to simply pierce new (locator) holes into the existing backing where the old badge was .
This can easy be done with a small phillips head screwdriver
Old 11-17-2017, 08:43 PM
shemp's Avatar
i actually thought about doing just that. I may give it a try over the holiday break.....
Old 11-17-2017, 09:25 PM
Tervuren's Avatar
I think there is a noticeable difference between the flat older style and the not flat new style.
It isn't just the red that makes it pop.
Compare the old black version to the new black version.
Attached Thumbnails Mina Gallery front grill options-used-2007-jaguar-xk-2drcoupe-8730-13382298-67-640.jpg   Mina Gallery front grill options-jaguar-xkrs-review-growler-badge-carwitter.jpg
Old 11-17-2017, 11:49 PM
Cee Jay's Avatar
I didn't realize the older emblems were smooth and roundish like that, my front badge is three-dimensional, as this:
I painted the recessed areas a very bright red, now it looks like this one, but without the 'ray' effect:
Old 11-18-2017, 10:04 AM
Tervuren's Avatar
I wonder which one Shemp's car has then.
The Original poster would have the flat one.
Your's looks nice, any pics of it painted red?
Old 11-18-2017, 10:40 AM
shemp's Avatar
I have the 3D black one in Cee Jay's post above.
Yea, post a pic of yours painted Cee Jay when you get a chance please
Old 11-18-2017, 10:45 AM
Cee Jay's Avatar
Forgive the dirtiness of the front end, lots of bugs.
I also have a CCFL around the emblem, hooked to the running lights.
The following 2 users liked this post by Cee Jay:
myexcursion (11-18-2017), shemp (11-18-2017)
