Buy back Option/compensation
There are a couple of active/unresolved threads here on this subject:
https://www.jaguarforums.com/forum/f...ssages-190827/
https://www.jaguarforums.com/forum/f...vation-191488/
...but neither seems to have reported on the final outcome/results as of yet.
I have seen many other threads in that the owners were unsuccessful in this regard. However I have also seen a few used cars for sale that have been branded as "Lemon Law" buybacks, so it does happen.
550R (11-20-2017)
Please clarify your question regarding "emmissions/performance" as neither of those things are viable within a buy back solution. Now, if you have a flawed exhaust & Jaguar has failed to successfully replace or repair it after 3 visits then that is a different animal and would likely qualify.
550R (11-20-2017)
Thank you for your reply. Yes, the exhaust noise (cracks and pops) have been muted/gone. Jag attempted to fix the issue 3 times with no luck and informed me that they can't fix it. Jaguar informed me that my vehicle was modified as per the requirements of the government. They also say as the manufacturer they reserve the right to make changes to specifications of their vehicles when necessary as per their warranty manual.
basically I am trying to find out what is the best option.
__________________
2015 Jaguar F Type R coupe RWD
BMW 335I
BMW 328i
Ranger Rover HSE
Porsche 911 Carrera 4S
BMW 330D M sport Wagon
1979 Mini 1100 Special
Thank you for your reply. Yes, the exhaust noise (cracks and pops) have been muted/gone. Jag attempted to fix the issue 3 times with no luck and informed me that they can't fix it. Jaguar informed me that my vehicle was modified as per the requirements of the government. They also say as the manufacturer they reserve the right to make changes to specifications of their vehicles when necessary as per their warranty manual. Basically I am trying to find out what is the best option.
I am not a lawyer nor do I attempt to play one on the internet but common sense would indicate that you don't understand legal aspects you are inquiring about. You have a number of problems with your statement & issue:
- Your signature shows a 2015 model. Did you buy it used? If so, lemon laws do not apply as you did not buy it from the manufacturer.
- If you bought it new, you would be hard pressed to explain why you waited 2 years to make a claim
- The exhaust is designed to pop and crackle. If it does, it is working as designed. If it does not pop or crackle then it may be possible that the dealership put an exhaust on that does not have the values that allow the ability to open and close the exhaust note.
Your only real options may be:
- Sell the car on the open market yourself
- Have as auto broker take it to an auction to sell it on your behalf.
- Trade it in on a Tesla or other vehicle with a quieter engine if that is your desire
- Alternatively, if making it pop & crackle is your desire than there are 3rd-party aftermarket system with the valves that can be installed but that may void any warranty as well so take that into consideration should you decide to go that direction
Received 3,126 Likes
Yes there was, but for some reason it doesn't seem to have fixed his car, and his dealer is maintaining that the car is "working as designed"
He could try taking the car to another dealer and tell them the issue and that he believes that his current dealer may have failed to have correctly applied the "correction" patch.
Based on the details I saw about the software "patches" in the F-Pace forum it would not surprise me to learn that his Jaguar dealer may not even be aware that they did not successfully complete the software upgrade. Numerous dealers had thought they completed upgrades to the audio system yet when investigated it turned out that they were leaving the code at the earlier version. Those same dealers may also be "technically challenged" on the F-Type software patches as well, right?
Dealers are now having to contend with being adept at technology and software rather than just spanners and more traditional mechanical skills, and I am not sure they are that well equipped to do so.
OP - have you considered taking it to another dealer, and asking them to apply the JTB fix?
That's pretty much what I have been thinking. There are certain pre conditions that have to be met for the patch to apply - a specific version of the SDD tool for example. I think that was the issue with the first K309 update I had, the dealer was using an older SDD version. When they applied the patch they had just moved into a new location with all new workshop equipment, and presumably an updated SDD.
Two different dealers tried to solve the issue with JTB 495 update, no luck. Jag also informed me that they have done everything they could and this is related to Government Emission mandate. What I did notice when I had a closer look at my car's service records, the car was updated with K309 once in 2016 and then again in 2017. I am not sure if this is standard procedure after every service!
