Fuel tank L/R switch operation
Old 01-13-2018, 05:17 PM
andys-GR's Avatar
Default Fuel tank L/R switch operation
This may be a dumb question.
I got my 84 started started today but I had to hold in the change over switch for her to run.
The switch is out showing the white band for RH and will not stay pushed in . However the 85 switch behaves the same.
Am I correct in thinking that it should stay pushed in so you don't see the white band?
Also the owners manual says there are illuminated arrows indicating the tank. I don't see any arrows.
Any input appreciated.
Old 01-13-2018, 08:44 PM
Doug's Avatar
Received 10,741 Likes on 7,097 Posts
Yes, the switch should stay in when depressed.
The bulb for the arrows might be burned out....but they're rather dim anyway. Hardly visible unless you're in very dark surroundings
DD
andys-GR (01-13-2018)
Old 01-13-2018, 09:13 PM
andys-GR's Avatar
Thanks, seemed like it should! I guess I have 2 XJ's with the same problem
Old 01-14-2018, 05:37 AM
sanchez's Avatar
Pushed 'IN' activates the left side tank and return. 'OUT' activates the right side tank and return. When pushed 'IN' the switch should stay in that position.
I had that problem on my '84 and the advice I was given on this forum was to spray some lubricant and exercise the switch which worked for me.
I have not seen any arrows on mine. I know if the white band is visible (switch out), the right side tank is being used. No white band visible (switch in), left side tank is being used. I used a lubricant for electrical components from ACE hardware.
andys-GR (01-14-2018)
Old 01-14-2018, 09:43 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
No lights visible in mine. and the white band on the edge, just barely.
but, it does swatch tanks just fine. so, I merely memorized, "left in, right out".
Side bar: This "new" keyboard seems to be responding to the Jaguar mantra". Exercise sticky keys to restore function!!!
Carl
Old 01-14-2018, 10:26 AM
andys-GR's Avatar
Thanks for the advice, I'll certainly try the lubricant.
In time I will be re-laying out that part of the dash so I may go for a toggle switch.
I was laughing a bit I found replacement switches on ebay for $500 ea and $34 ea !!
Old 01-14-2018, 10:32 AM
JagCad's Avatar
That sure sounds like government procurement.
Old 01-14-2018, 10:43 AM
Doug's Avatar
Keep us posted.
I myself am planning some layout and switch gear changes in the center panel....but they're a bit down on the list at the moment.
DD
Old 01-14-2018, 12:57 PM
Received 7,849 Likes on 4,749 Posts
There are supposed to be 'arrows' very faint on the switch.
Red arrow is the PORT side, Green arrow is the STARBOARD side.
Green arrow is at the top and the Red arrow is at the bottom on the face of the switch.
Can see it better with back lighting.
bob
Old 01-14-2018, 04:37 PM
Jose's Avatar
Received 2,425 Likes on 1,826 Posts
in my 1984, the switch has a band at the bottom of the fascia which lights Red when the switch is pushed IN. The Red light goes out or is not seen when the switch is pushed OUT. As far as I know, it is the switch that came from the factory since I have never replaced it.
The arrows that he refers to must be on the left side of the switch, since my car has 1 printed arrow indicating "push" on the left side of the switch.
Old 01-14-2018, 07:54 PM
Doug's Avatar
Jose, that rings a vague bell with me but all I ever seen, FWIW, is the type with arrows
https://i.ebayimg.com/images/g/w9oAA...9hn/s-l300.jpg
I think it's the map and pillar light switches that have the bars
http://i.ebayimg.com/images/i/121561...-1/s-l1000.jpg
DD
Old 01-14-2018, 08:20 PM
andys-GR's Avatar
Thanks guys I will keep you updated as the project evolves.
Old 01-15-2018, 02:30 AM
Received 8,911 Likes on 5,277 Posts
Switches in question, Series 2:
Out rightGreen.
In Left red.
Pillar, map lights On.
The following 2 users liked this post by LnrB:
andys-GR (01-15-2018), motorcarman (01-15-2018)
Old 01-15-2018, 09:11 AM
Dutch-Cat's Avatar
Just order parts number DAC1356# from SNGBARRAT'S
and for US$ 41.99 you'll get a brand new OEM part on your doorstep.
https://www.sngbarratt.com/us/#!/Eng...0-d5efbdd0e820
Old 01-15-2018, 04:19 PM
Jose's Avatar
Elinor's switches are very similar to the Series 3, and you can see the red band at the bottom of the fascias that lights up when you press the switch.
there is not a second bulb for the red bands, they just reflect or "light up" when the switch is pressed in and the red band is closer to the bulb.
The following 2 users liked this post by Jose:
86jag
05-12-2023 07:06 PM
SouthernGypsy
01-23-2020 05:59 AM
platinummaker
12-30-2017 12:20 PM
86jag
07-13-2016 10:13 AM
mTTs
10-14-2013 07:37 AM
Quick Reply: Fuel tank L/R switch operation
