Battery hooked up backwards !!!
Old 02-05-2018, 05:56 PM
shorty one's Avatar
Default Battery hooked up backwards !!!
Hello all,
The battery on my 1998 xj8 when a new one was installed had the battery cables hooked up in reverse.
Saw some smoke coming out from under hood and immediately disconnect cables to the battery.
What do you think got burned up?
What damage did this do to the car?
Fusable Link, Alternator ????
Please help.
Old 02-05-2018, 09:59 PM
avern1's Avatar
Received 1,317 Likes on 1,004 Posts
I hate to state the obvious but, hook up the battery correctly and try to start the car and try to determine what is not working. If hooked up correctly and you have no power then I would start with the High Power fuses. They are mounted in the trunk on the front wall. They are 2 amp 250 amp fuse links. If you had the ignition off and the battery connected incorrectly the only cable receiving voltage would be the one on the right side of the vehicle running from the battery to the bulkhead connector in the engine compartment on the right side and then on to the starter.
Check the bulkhead connector for heat damage and the cable on each side of the bulkhead connector.
shorty one (02-12-2018)
Old 02-05-2018, 11:57 PM
King Charles's Avatar
Received 1,019 Likes on 740 Posts
+1 above, check all the heavy fuses.
Old 02-06-2018, 01:30 AM
Lady Penelope's Avatar
Received 1,383 Likes on 1,087 Posts
Been there , done that . Easy to do and all is not lost . Cheap recovery .
Mine was just fuses and the voltage regulator .
Stereo fuses , Instrument Panel fuses , and a new alternator regulator as the rest of the alternator is fine .
Once your gets those specifics put your finger on the 1 king relay in the corner of each fuse box to verify that that section is powering up and verify the related items out from there .
Mine is a X300 but the X308 is pretty much the same
I'll get you a print of the fuse locations and a part number for a regulator .
http://www.jagrepair.com/images/Auto.../jagxj1998.pdf Relays page 30
http://www.jagrepair.com/images/Elec...jm18151280.pdf Fuses page 79
Regulator part # JLM20498 can be sourced cheaper from a other source .
https://www.jaguarclassicparts.com/u...nator-assembly
Any questions , just ask .
The following 2 users liked this post by Lady Penelope:
avern1 (02-06-2018), shorty one (02-12-2018)
Old 02-06-2018, 07:28 AM
1 of 19's Avatar
Lady Penelope, you are a wealth of knowledge... Thanks
Old 02-06-2018, 08:13 AM
This website is a wealth of knowledge , I'm just passing it along .
You can hook the car up to a battery charger for the repair processes as the alternator has to come out to be spun tested for free at the auto parts store .
https://store.alternatorparts.com/in...regulator.aspx Not sure if this is the right one, there is a part number stamped on the back side .
Verify you can get the bolt off between the regulator and the brushes as mine was stuck . Drilled out head of bolt as the tail stays with the regulator or you can order new brushes depending on wear on the same website
Old 02-06-2018, 06:20 PM
JagV8's Avatar
Never has "just" been so inadequate!
Old 02-07-2018, 01:45 PM
Robman25's Avatar
I managed that, not once but twice in quick succession (don’t ask!) fried the fuel pump circuit on the ECU, this was on a ‘92 XJ40 so the 308 may have some better protection.
Hope I’m not a harbinger of disaster.
Old 02-15-2018, 06:51 PM
shorty one's Avatar
My car is a 1997 XJ6,
Checked fuses. 5 blown.
Hooked battery up correctly.
Smoke came rolling out of altenator.
Will pull altenator and have it rebuilt.
Lady Penelope (02-15-2018)
Old 02-15-2018, 08:02 PM
If it is a straight 6 X300 series sedan vs. V8 X308 , the regulator is part # IN435 . Easy to swap out and the auto parts store will spin test it . The alternator comes out of the top but bolts from the bottom . The engine mount may bite the alternator and not let go but just lever out with a lever . File down before reinstalling . there is a regulator fuse that feeds the alternator excitation voltage . Pic below is for X300 only :
https://www.ebay.com/itm/NEW-QUALITY...-/291911326961
Attached Thumbnails Battery hooked up backwards !!!-x300-in435.jpg   Battery hooked up backwards !!!-x300-generator-wires-untitled.png
Old 02-15-2018, 08:40 PM
Received 7,878 Likes on 4,762 Posts
Please post in the correct forum for reliable info.
bob
Old 02-24-2018, 07:02 AM
shorty one's Avatar
Thank you all for input.
As to date. Had 6 blown fuses found.
Alternator fried.
Had it rebuilt at a local alternator rebuild shop.
Cost $180. Not sure if this is a good price. Not a complete rebuild as he left the old bearing and pulley wheel.
Yes, the alternator is very tight in the motor frame mount. Had to lever it out.
Ground down alternator before reinstall but apparently not enough. But, apparently not enough.
It is still very tight and difficult to reinstall as a result.
I had to tap it in place with a large screw driver and hammer. I am hoping the tapping on the alternator case did not damage it.
Old 02-24-2018, 07:33 AM
The aluminum casting on the alternator could have cracked and as the magnetic winding pluses put a mechanical strain on the casting it might come apart under load or time . This would have bad consequences if it tore into the engine block . Best to remove it and inspect it to be safe . The casting can be rewelded up to a point and you have to look around for someone to do aluminum . Has to be rewelded as the 2 halves are put together as they will warp and not go back together .
This may be nit picking but better safe then sorry . Mine is cracked by trying to split the halves without removing the pulley as I wanted to replace the bearings while I had it out and I found a auto shop to do this . Muffler shop deals with steel which is a different process .
http://www.lincolnelectric.com/en-us...ng-detail.aspx
Old 02-24-2018, 10:57 AM
shorty one's Avatar
Well.....God is good.
Got the rebuilt alternator in.
Hooked up battery.
Seems all is good..
Old 02-24-2018, 11:00 AM
shorty one's Avatar
I did not tap it very hard with hammer and screw driver.
Where did tap was the thick part of the case.
But......you never now.
Kind of like saying, I only pulled the pin from the grenade once......
Old 02-24-2018, 01:13 PM
shorty one's Avatar
Well......went back out a couple about one hour later.
Put key in, steering wheel adjust, interior lights on.
Nothing else.
No dash board lights,,, turn key nothing.
Disconnect battery, re-connect.....nothing again.
New to the Jag.
Ugh.....
Old 02-24-2018, 01:41 PM
Feel for the king relays in each ( except the LH engine fuse box ) of the fuse trays to click as you turn the key enabling power to the fuses . 4 total as you may have at least 1 closing but not all , they can be swapped . If you feel 1 relay click proves somewhat the ignition switch is OK controlling these relays to close .
shorty one (02-24-2018)
Old 02-24-2018, 03:45 PM
shorty one's Avatar
Went out and tried key numerous times over about 15 minutes.
Removed battery cables ad reinstalled.
Tried key ten more times over another 10 minutes.
Sat in car doing nothing for ten minutes and turn key.
Walla.......dash lights come on.
Turn key car starts.
Drove for 15 minutes.
Stop, turn off wait few minutes.
Turn key, car starts right up.
I will go and check the King Relays as suggested.
Old 02-24-2018, 04:05 PM
If you're working by yourself you can turn off everything to reduce load across the king relays power sockets and with the key in the on position you can remove and reinstall the relay and feel for the click . Then move to the next king relay . One may be intermittent so it makes it harder . If you can list the items not coming alive you can track down the specific one .
Old 02-24-2018, 04:27 PM
shorty one's Avatar
nothing on dash lights up
interior lights work
power seats work
power steering adjust works
Quick Reply: Battery hooked up backwards !!!
