Replacing Ignition coils on a 2000 XJ8
Hello, guys. I just purchased this car Sunday. The check engine light is on and it goes into restricted performance mode. The guy I bought it from has done a lot of work to the car and I have all of the receipts for the work done.
I took the car this morning to Auto Zone to have the codes read. A ton of codes popped up. Codes for all the cylinders misfiring popped up but the way this car runs there is no way the cylinders are misfiring. Codes also popped up that said the left and right banks were running too lean. The car runs great, had it up over 100 miles an hour. When the restricted performance light comes on nothing happens to the way the car runs, it still sets sail down the highway so I'm not in any hurry to get this done.
The print out from Auto Zone recommends changing spark plugs (which has already been done) and replacing the ignition coils which is what I am going to try.
What my question is, is how hard of a job is this? My dad is an excellent mechanic on old muscle cars so he will be helping me. Is this a job that a rookie can do or is it a tough job?
Changing ignition coils is extremely easy, remove the 8 small bolts holding the cover on each valve cover, each ignition coil is held on by two small bolts, remove and replace. But you may want to investigate your codes some more if you know the car isn't misfiring and yet you are getting codes that indicate it is.
Don B (03-21-2018)
Go hunting for air leaks etc before you get to replace the cats as well as having to fix whatever is wrong.
Don B (03-21-2018)
Don B (03-21-2018)
Stop throwing parts at it and get some information. I doubt all the coils are bad. If the part that's taped comes out of the cam cover and is an accordion hose it's probably the full load breather (right bank) or part load breather (left bank)
Download the workshop manual JTIS21 from the Sticky to learn the repair and maintenance procedures. Also contact SNG Barrett from the vendor directory on the right column of the page and request a free parts manual. Lots of drawings.
The following 3 users liked this post by RJ237:
Don B (03-21-2018)
Yep, that's the part, but you can do better on the price. I just got one from jlrreno.com for $15.76. Replace that first. Also, get a scanner that reads live data. You can tell a lot about what the engine is doing and read your codes without having to go to Autozone.
P1111 is a good code; that means that all of your emissions components are working.
Mark
XJR-100
Mark
XJR-100
Tinsletown (03-23-2018)
The following 2 users liked this post by RJ237:
Don B (03-21-2018),
Hey guys and gals. Got the part last night and changed it this morning. Didn't help the rough idle. Another code that came up was P1384 and P1396 for the VVT solenoid. From all the searching I have done on it in these forums it looks like a number of things can cause this error code, and it also said this is another symptom of a rough idle. The timing chain and tensioners have been changed 3k miles ago and the threads I read said messing with this can cause these solenoids to throw error codes.
From my searching on these forums it said that I might not be getting enough oil pressure at idle. And to do an oil flush and try a higher viscosity oil. Right now it has 5w30 synthetic in it.
Just ran the codes again and this time P1396 didnt come up, only solenoid A
I'm also going to clean the Mass air flow sensor.
Can someone tell me what the zip tie is around on the picture i posted?
If you're referring to the piece with a white zip-tie just forward of the full load breather hose, that appears to be your A-Bank VVT connector (my engine doesn't have VVT, but it looks like that is where the solenoid would be). Since you're getting a code from that part, pop the zip-tie and see why it's there (broken connector tangs?) and make sure there's good contact between the two pieces of the connector fitting. Have you downloaded the workshop manual (JTIS)? There are a few pin point tests in there to check the eletrical current to the VVT solenoids.
Mark
XJR-100
Mark
XJR-100
Tinsletown (03-24-2018)
Mark
XJR-100
Mark
XJR-100
boostedhks
08-30-2011 04:22 PM
MLRocafella85
06-18-2011 02:19 PM
WillieE
05-17-2011 11:14 AM
