DI misfires...my saga of frustration
Old 08-13-2018, 07:23 PM
bigdhenderson's Avatar
Default DI misfires...my saga of frustration
2010 XKR 5.0, 75k miles.
So, as some of you may have seen my 75k mile carbon build up thread. What started that endeavor was a cylinder 7 misfire/restricted performance.
I started with plugs. Put new plugs in. No change. Swapped coils around. No change. Got pissed and ripped off the supercharger, cleaned the intake valves, put 8 new injectors in. Start it up today, have cylinder 2 misfire (#7 misfire is fixed) . Swap coils with 1, no change. Swap plugs with 1, 2 looks brand new unfired almost, 1 looks fired.
Does anyone thing that brand new injector is faulty? Or could there be another explanation for this.
Old 08-13-2018, 07:27 PM
sparky fuze's Avatar
Not questioning your skill-set, but double-check that you have put everything back together correctly and completely. It may just be a silly over-sight of a wire here, or something else there. It's easy to miss something especially when you are rushed or pissed off.
Old 08-13-2018, 07:33 PM
Checked and double checked...the 5.0 is strikingly a very easy engine to work on....but this has me stumped...and the thought of having to pull the fuel rail again has me depressed.
Old 08-13-2018, 08:27 PM
Ranchero50's Avatar
Swap the injectors, similar to the coils. PITA but it isolates the replaceable components from another problem. In the Navy we called it half splitting the problem. Pick a point 1/2 way between known good and known bad and check there.
Queen and Country (08-14-2018)
Old 08-13-2018, 08:32 PM
The reason i havent done that yet is because it's direct injected...the Teflon seals and retainers need to be replaced anytime an injector is removed...so they say...
anyone have any experience NOT doing this?
Old 08-13-2018, 08:40 PM
Cee Jay's Avatar
Received 5,150 Likes on 3,085 Posts
Originally Posted by bigdhenderson
The reason i havent done that yet is because it's direct injected...the Teflon seals and retainers need to be replaced anytime an injector is removed..........
Yep, and there's a special tool to first stretch the seal then another one to shrink it back down in two stages.
Old 08-13-2018, 09:05 PM
Yeah, a special tool and seals I don't have on hand, and hoping to solve this tomorrow before I have to go out of state for work the next few days.
Old 08-14-2018, 05:13 PM
Moved #2 coil to #8. Now have misfire code for 2 and 6...wtf is going on here
Old 08-14-2018, 06:11 PM
Cee Jay's Avatar
When is the last time you did a Hard Reset? It helped a problem of mine once before.
Old 08-14-2018, 07:03 PM
Battery was disconnected over the last 2 weeks while I've been working on it. Otherwise it's just been me clearing the codes with torque pro
Cee Jay (08-14-2018)
Old 08-15-2018, 09:00 AM
SinF's Avatar
I feel your pain. While it is possible that brand new injector is faulty, when you heard hoofbeats, think horses and not zebras.
Have you considered that this issue may be fuel pressure related and not injector related? If one of the second stage pumps is marginal it can wreck all kinds of havoc with DI and look like injector's fault.
Old 08-15-2018, 12:54 PM
It has crossed my mind, what is nominal pressure supposed to be? I'm getting over 2k when I rev it up, around 900 ish at idle
Old 08-15-2018, 05:58 PM
Sean W's Avatar
Received 4,164 Likes on 2,334 Posts
What codes are you getting and are they just moving to different cylinders as you make the swaps or are you getting new ones too?
Old 08-16-2018, 07:03 AM
Misfire cyl 2 seems to stay constant, along with misfire detected within first 1000 rpm code. The other cyl misfire codes come and go as I switch. Out of state at the moment but when I get home all new coils will be waiting, so if at the least I hope I can rule out a bad coil. I'll have a new engine before too long!
Old 08-17-2018, 07:58 PM
New coils. New injectors. New plugs. Still a cyl #2 misfire. P0302 & P0316 ...No other codes.
I'm about to burn it
Old 08-17-2018, 08:05 PM
Ranchero50's Avatar
Do a compression check on all 8 cylinders. Possible a carbon chunk held the valve open and it got bent. It happens and doing the test will help isolate the problem.
Old 08-17-2018, 09:54 PM
jagtoes's Avatar
What is strange is this whole thing started with #7 mis-firing. Then after all of the work it's now at #2. Hard to believe a new injector would be bad but you never know. Did you or can you use a noid tester to see if there is power to the injector. Also when you pull the plug what does it look like. Dry or wet . As I said something strange going on.
TXFireblade (08-18-2018)
Old 08-17-2018, 10:05 PM
2 brand new injectors...I pulled the first new injector tonight and put in another brand new one. No change.
Old 08-17-2018, 10:08 PM
Plug looks dry, almost un-fired. Going to pick up a noid tomorrow and really start to trace back all my wires.
Old 08-17-2018, 11:36 PM
O2 values show low on bank 1. So I'm lean due to the misfire.
Quick Reply: DI misfires...my saga of frustration
