Dead battery
Old 10-19-2018, 10:04 AM
jbottomley's Avatar
Default Dead battery
Ok...I have a 2003 Jag XJ8. I took it to a upholstery shop and they removed the front seats. Redone both seats. I pick it up and runs fine. BUT if I leave it sit over night the battery goes down...have to jump start. I can drive it all day....restarts fine...sits over night and dead...any ideas what might be wrong or what to try. Thanks.
Old 10-19-2018, 11:11 AM
Jhartz's Avatar
Two things, off the top of my head: first, they unhooked the battery -- need to tighten the cables; two, they have frayed and grounded a wire going to one of the seat modules while doing the upholstery. Lots of threads on how to find the right fuse or relay effecting the seat systems - run a meter to determine if it is live when the ignition is off.
Old 10-19-2018, 12:26 PM
jbottomley's Avatar
can I unplug the seat to determine if thats it? Just to narrow it down.
Old 10-19-2018, 12:30 PM
Jhartz's Avatar
I think so; Or maybe pull the appropriate fuze. But maybe one of the folks better at electrical issues will weigh in.
Old 10-19-2018, 12:33 PM
jbottomley's Avatar
im hoping...cause I can fix anything if told how to do it...its just electrical isn't my forte....
Old 10-19-2018, 12:47 PM
avern1's Avatar
Received 1,317 Likes on 1,004 Posts
The problem is caused by a parasitic drain. Most likely a wire was damaged during the removal or re-installation of the seat. Try looking around under the seat and see if any wires are pinched int he seat rails. Next check the seat functions. Does it work in all directions? Lastly set the drivers seat in to the normal driving position and from under the seat remove the seat control module. Did that clear it? If not re-connect the drivers side and do the passenger seat. This should isolate it to one seat or the other. If that doesn't resolve it then follow the link below for the easiest way of finding a parasitic drain. Go to post 10 for the video instructions.
https://www.jaguarforums.com/forum/x...estate-193954/
Jhartz (10-19-2018)
Old 10-19-2018, 02:04 PM
jbottomley's Avatar
I pulled the negative cable off and hooked up a test light....light is bright as heck....how long should I have a drain...waiting for everyrhing to shut down....like modules and such?
Old 10-19-2018, 02:30 PM
jbottomley's Avatar
I have pulled every fuse in trunk...test light still on....I have pulled every fuse in back seat near your ankles...I have pulled every fuse in the 2 fuse panels under hood...test light still on..any idea if more fuse panels?
Old 10-19-2018, 03:04 PM
avern1's Avatar
Pulling fuse want help find the culprit. Take a look at my previous post for your troubleshooting. It is the most direct way to find the problem. If you are shorted to grouund it will always show on the test light. The vehicle will not power down with door, trunk, hood or glove box open. It will power down after a few minutes with everything closed up but as soon as you open anything it springs back to life.
Old 10-19-2018, 04:29 PM
jbottomley's Avatar
ok...sounds like a plan...I will post after I try this. Thanks for info.
snkpkp
01-14-2021 09:52 AM
jarrettjjackson
03-20-2019 11:17 AM
hal
09-05-2017 04:23 PM
aratnam
07-07-2016 07:25 PM
supraman
07-17-2011 11:14 PM
Quick Reply: Dead battery
