XJ6 Sump Plug Repair?
Good Evening All,
I'm getting very close to getting my XJ6 back on the road and as such I've giving everything the once over. First problem found! I have oil leaking from the sump plug. I've removed the plug and it looks like the sump has had a previous helicoil repair? I'm assuming that they weren't helicoiled from the factory?
What are my option for repair? I have found something for AJ6 engines, but not the XK?
Woz
Woz
I went to the local parts store, happened to be my place of employment at the time, and found a 14mm sump plug, Mitsi/Toyota/dunno, and then snooped around some more, and found a 14mm Taper tap, and drilled the sump to the size for the tap spec, and that I forget now, but since I was using a 1st taper thread tap it was only a "lick", and rethreaded that alloy sump to take the 14mm sump plug, simple.
THEN
Dont let idiots change your oil.
NO, they were not helicoiled from the factory, and usually oil will seep between the coil and the parent, and ya got a leak.
THEN
Thanks Grant,
I've taken a closer look now and I can clearly see the helicoil (of the wrong depth!) but, the sump plug thread is 5/8-18 UNF (15.875mm x 1.41mm), so an M14 won't be enough. I'll need to find the helicoil thread size and maybe make an adapter or just go up to 3/4 UNF and use a new sump plug?
Commodore V6, say VXish has a 19mm threaded sump plug, memory here, as I am not at work at the moment. They do have a standard 14mm plug and then this option for the bigger one. My sons V6 S/charged has the big plug as supplied by GM, so not molested.
Duck into Super Cheap, they should have a chart for all cars, Kelpro is one brand, and pick one that suits, and then a tap, and done and dusted.
Late S3, and AJ6/16 has a "monster" thread sump plug, but I reckon that is going too far, or maybe not.
Well the drill size for the current helicoil is 41/64" (16.27mm), so you need to go to 3/4-16 to remove the helicoil thread. The 3/4-16 needs a 17.5 hole to tap into.
Although, being Aus it will be easier (cheaper) to go with a metric thread. M20x1.0 would do the trick. I'll have a shop around tomorrow.
Grant Francis (02-17-2019)
OOPS.
Very sloppy repair by any standards.
Maybe, unwinding it carefully, cleaning with Solvent (Carby cleaner etc) and loctite the coil into place. Then a decent copper washer, or a Dowty washer, nd should be fine.
The depth is no matter, just the security and the face finish is what gives the seal.
Woznaldo (02-17-2019)
Received 2,399 Likes
The following 2 users liked this post by JagCad:
Grant Francis (02-17-2019),
YUK!!!
Who ever "installed" that Helicoil made mess. As I get it,. once the coil is seated in the new clean threads, the tang is to be busted off, It's location job done.
It looks like there is enough "meat" left for a new bore and a clean tap. And, yeah, the threads are straight and as sucj do not seal, they merely fasten. use a good washer and all should be well....
Carl
Carl
Job done! Hole drilled out to 17.5mm and tapped to 3/4-16 UNF. Just need the correct size crush washer now. I used a Dremal to gently chamfer the outside of the hole as a chunk had come off around one half. Then used the drill taking care to align it perpendicular to the face.
The hardest part was removing the swarf from the sump! The larger hole allowed me use my little finger to get most of it. I then threw some fresh oil into the top of the engine to flush it out.
The following 2 users liked this post by Woznaldo:
Grant Francis (02-19-2019),
o1xjr (02-22-2019)
orangeblossom
05-19-2016 12:07 AM
RaceDiagnostics
10-12-2012 12:00 PM
