F-Type R vs F-Type SVR
Old 02-17-2019, 02:56 AM
Biofreak's Avatar
Default F-Type R vs F-Type SVR
So on a small breakfast run this morning I had an interesting outcome against a SVR and Huracan.
This is with only the Bottom Pulley with stock software. Quite impressive methinks.
Before Jimlighta's thread got locked, there was mention made of the bottom pulley causing issues without software. And how it can't be run without an engine light.
I'm not experiencing any of these issues so am just wondering if anyone can share what the dangers are.
enderle (02-18-2019)
Old 02-17-2019, 08:50 AM
RIRR's Avatar
I'm afraid I can't help you with possible issues from running the bottom pulley without a tune, but I am interested in knowing what year R you have?
Old 02-17-2019, 08:53 AM
RGPV6S's Avatar
I just asked VAP that very question a few days ago. They replied that you will/may get overboost CEL codes if car is driven hard.
Old 02-17-2019, 09:57 AM
Unhingd's Avatar
Received 4,636 Likes on 3,359 Posts
I certainly got overboost codes when my lower pulley was installed, but I already had the upper pulley on as well. The data tables just didn’t cover boost pressures up to 20psi. VAP had to build out those tables for me.
Old 02-17-2019, 11:38 AM
Biofreak's Avatar
It's a 2014 RWD model
I drove it very hard today and no CEL's... Does altitude affect boost pressure on these cars?
Old 02-17-2019, 12:51 PM
RGPV6S's Avatar
Joberg is at almost 6000 ft if I remember correctly. That could explain the lack of codes as superchargers lose efficiency as altitude increases .
Just a thought, if you head to the Capetown area near sea level you might see some codes.
Old 02-17-2019, 01:04 PM
Byrnout's Avatar
RWD F-Type R vs F-Type SVR
RWD F-Type R vs Huracan
Awesome get up and go Biofreak! I am always amazed at just how fast the RWD is when you hook it right. Excited to get new PS4S shoes to hopefully make it easier.
So you just have the lower pulley? Nothing else? Is it possible that with the $800 race chip Jimlighta had he was actually pulling 3.0Xs to 60 in a '14 V8S as he said he was? Don't want to recreate that forum here but you actually have video evidence that is impressive.
Old 02-17-2019, 02:54 PM
Unhingd's Avatar
That would explain it. 3 psi less absolute intake pressure at 6000ft. Well within the limits of the OEM data table.
Old 02-17-2019, 04:06 PM
eeeeek's Avatar
The video would be so much better if the phone was rotate 90 degrees. Impressive results.
Old 02-17-2019, 05:17 PM
scm's Avatar
scm
scm is offline
Received 1,384 Likes on 1,051 Posts
I've often wondered why so many videos are shot in portrait mode - I just figured they didn't have their eyes side-by-side like most people.
Old 02-17-2019, 11:22 PM
Biofreak's Avatar
Tell me me about it... At least the wife took the video
Old 02-17-2019, 11:26 PM
Biofreak's Avatar
I'm only running the pulley at the moment from a performance point of view and was on 95Ron pump fuel.
H&R springs and PS4S tyres on the suspension side.
Old 02-18-2019, 06:44 AM
Paul_59's Avatar
Banned
Regarding 0 to 60mph in 3.0 secs in RWD V8 F type (even tuned)
My comments would be
1) extremely impressive
2) don't believe it unless backed up by Vbox / performance box or similar gps(10Hz) based data
Old 02-18-2019, 06:47 AM
Paul_59's Avatar
Banned
Indeed one of the first uses of supercharging was on aircraft, whilst this could give power increases at lower altitudes its main benefit was to reduce the power reductions due to lower density of air at higher altitudes
Old 02-19-2019, 01:48 AM
Biofreak's Avatar
That explains it!
Well, let's hope VelocityAP can sort out the issues I'm having with their map. Then it's rematch time with the Huracan
Old 02-19-2019, 07:31 AM
Unhingd's Avatar
When you have the tune done, you'll want to specify it for 91 AKI fuel. There's usually an 8 point difference (depending on blend: E10 usually a 10 point differential) between RON and MON. AKI is the average of the two.
doctordeuce
11-03-2023 02:18 PM
ipitythefoo
03-17-2022 05:39 PM
Jaguar Forums Editor
Jaguar Press release
04-29-2015 05:28 PM
03-27-2015 06:56 PM
Quick Reply: F-Type R vs F-Type SVR
