Sponsored by: DashLynx
Coolant Temps in Hot Weather
Old 06-19-2019, 01:26 PM
Reverend Sam's Avatar
Default Coolant Temps in Hot Weather
I just had my water pump and one of the coolant pipes changed by the dealer. Here are the temps I'm seeing (see pic). Is this normal? If I'm sitting in traffic it gets up into the 210's. If I'm driving down the road it drops to the low to mid 190's.
This seems abnormal to me, but the temperature has been in the mid 90's lately.
Old 06-19-2019, 01:34 PM
Sean W's Avatar
Received 4,166 Likes on 2,335 Posts
I think mine has popped up to 204 in traffic and under normal driving is about 194-197.
Old 06-19-2019, 03:09 PM
gkubrak's Avatar
Sitting in traffic on a 85 F degree day I checked mine was about 208 F. Seems normal. While driving or at night its around 197 F.
I also did my water pump, a few hoses and thermostat recently so I'm not too worried.
Old 06-19-2019, 03:10 PM
pwpacp's Avatar
MuNA XK averages 186F but can top out at 204F when sitting in traffic if that helps. (outside temp was 85)
Old 06-19-2019, 04:10 PM
Torque was showing me today that the temperature varied by 25 degrees, from 190 to 215. The 215 seems a little hot. I wonder if my thermostat is stuck partially open, or maybe its not opening all the way.
Old 06-19-2019, 05:01 PM
Sean W's Avatar
From your model's service manual,
"On both naturally aspirated and supercharger vehicles, the thermostat begins to open at 88 - 90 ーC (190 - 194 ーF) and is fully open at 102 ーC (216 ーF)."
Old 06-19-2019, 06:43 PM
THANK YOU!!!!!! Now I won't worry so much about the temps. That's probably why manufacturers use an idiot light these days. They probably used to get all sorts of warranty repair requests when the needle was a tiny bit too hot.
Old 06-19-2019, 07:25 PM
jagtoes's Avatar
2012 XKR runs normally at between 190* F to 215* F during any temperature. I would get concerned at anything over 225* F .
Reverend Sam (06-19-2019)
Old 06-19-2019, 07:56 PM
Thanks Jagtoes! I've been obsessing about the temp ever since the $2000 water pump issue. You and Sean have eased my concerns.
Old 06-19-2019, 10:18 PM
Sean W's Avatar
agreed. Give your self peace of mind and set the alarm on your torque pro to go off @ 220*F.
Old 06-19-2019, 11:15 PM
ralphwg's Avatar
Received 1,183 Likes on 895 Posts
Your XKR is extremely normal.
Old 06-20-2019, 07:28 AM
yidal8's Avatar
Does the OBD II interface device for the torque-pro increase battery drain when car is off?
Old 06-20-2019, 08:10 AM
jagtoes's Avatar
FYI The thermostat allows rapid engine warm-up by preventing coolant flow through the radiator and by limiting coolant flow through the cylinder block when the engine is cold. During warm-up and at engines speeds above approximately 1800 rev/min, a by-pass valve opens to control the coolant flow and pressure, to protect the engine components. When the thermostat opening reaches 6 mm (0.24 in.), the by-pass flow is shut-off. When the thermostat opening exceeds 6 mm (0.24 in.), the radiator coolant flow is further controlled up to the point where the thermostat is fully open. At this point maximum radiator coolant flow is achieved to provide maximum cooling.
Old 06-20-2019, 09:26 AM
Sean W's Avatar
yes, though minimal, and there are three options:
1) Buy one that automatically shuts down - I tried this and had to reboot it each time. It restarts itself but didn't pair unless you press the reset button. PIA.
2) Unplug it from the OBD port every time you shut down the car. You risk damaging the pins in the OBD port doing that daily.
3) Buy a battery maintainer, which you should have anyway as our cars demand a lot of battery usage. With a maintainer, you won't have to worry.
Old 06-20-2019, 10:26 AM
DannyJ's Avatar
1) Buy one that automatically shuts down - I tried this and had to reboot it each time. It restarts itself but didn't pair unless you press the reset button. PIA..
I use this one. It shuts down and wakes up fine each time
Old 06-20-2019, 11:40 AM
SinF's Avatar
In-dash temperature gauge isn't actual engine temp but a running average, so most people won't be able to tell you unless they used a probe or OBD tool.
In general terms, 210 seems to be a bit high even with AC on. Have you checked operation of your auxiliary fan? Also, not sure if XKR has a heat-trapping engine cover like F-type does, if yes - remove that right away. On my F-type removing engine cover lowers engine temp a great deal.
Old 06-20-2019, 12:45 PM
Sean W's Avatar
he was asking about an OBD device that interfaces with torque. Is that what yours is?
Old 06-20-2019, 02:10 PM
bocatrip's Avatar
I知 driving my 2010 XK (with10,000 miles on odometer) in 95 degree florida heat with the original water pump! No temp gauge but I do make sure my coolant level is always topped up before every drive. So far no incident but I知 always somewhat uneasy. My trips are usually no more than 50-60 miles at a time. Maybe I値l be lucky and not see any steam from under the hood for years! Taken my car to every Jaguar dealer as well as my Indy and no water pump leak can be found although I do smell coolant with a very small loss. All I can do is wait. For the amount of miles I put on (less than 1,000 miles per year) it might not fail on my watch. I知 no youngster so who knows how many more years I値l have the car!
Old 06-20-2019, 02:16 PM
Cee Jay's Avatar
Received 5,159 Likes on 3,090 Posts
Also a 2010 with original pump (checked, no leaks, squeaks or rattles) and I do get a bit uneasy when the temps get above 215 or so, but it has never touched 220, even on 100+ days.
Maybe I should remove the engine cover anyway..........
Old 06-20-2019, 02:31 PM
bocatrip's Avatar
How many miles on your car? Are you the original owner? Are you certain the pump was never changed? Do you lose any coolant?
Quick Reply: Coolant Temps in Hot Weather
