Fuel in coolant
That’s a new one for me. Not saying it couldn’t happen, but have never heard of unburned fuel in the coolant.
Draw a sample of coolant into a cup, using an old turkey baster. Let it sit for an hour or two. Any fuel present should separate and rise to the top, leaving a sheen.
At minimum, beg borrow or steal a cooling system pressure tester and pump up the system to the value on the cap. If the pressure rapidly decays, the system has a leak.
Next, test for the presence of combustion byproducts in the cooling system There is an inexpensive tester that uses a special chemical that changes color to indicate a fault.
For the misfires, are you getting any codes? Is the check engine light illuminated? Or worse, is it flashing? If flashing, that’s meant to grab your attention that catalyst damage is likely to occur, and you should pull over and shut off the engine as soon as safely possible.
S-Type Owner (06-24-2019)
Many codes that go away but the no 5 misfire remains constant. Sympts, shaking on start up at first thoight it was the cats til the cat codes all went away. Aftwr maf oring replacement. Now misfire and shaking constant resulting in loss pf power and restricted performance. Major fuel smell at start up goes away after driving abit. Fuel filter was dumped oit and i blew air right through it so i put it back on. Waiting now for a new k and n filter in the mail.So im a rideshare driver and i have to work so i unplugged the maf which allows me to make it over hills but the shaking doesn't go away.
On a 2008 MY 3.0, cylinder number 5 is going to be underneath the intake manifold. Not an easy fix. I would really suggest you get some proper diagnostics done on your engine. The Jaguar version of the Duratec V6 is normally pretty bullet proof, but this excludes serious neglect. A small issue can morph into serious problems if left unresolved.
BTW,about all a K&N air filter will do for you is deposit oil on your MAF sensor over time...
No feedback either way on a K&N fuel filter. Sorry.
I do understand your predicament though. How many miles are on your S-type and what is your location? Hopefully some forum member may know an indy shop that may be able to do a quick diagnosis, fix and get you bak on the road before any permanent harm is done...
I had another thought on the fuel odor in the coolant. Could be cylinder #5 isn't firing for reasons still unknown, and that unburnt fuel is getting past the rings into the crankcase and diluting the oil. Said oil may be getting into the cooling system through a bad gasket or who knows what. That fuel smell in the coolant may be from oil diluted by fuel. Pull the dipstick and check for a fuel smell there. Check the oil cap, too. A milkshake foam indicates coolant getting into the oil. So many possibilities. The poor car is screaming for some basic diagnostics, versus continuing to be driven like this.
Also, since you mentioned a misfire, you are legally required to listen to my canned speech on the subject. This has become a drinking game, where all forum members must down a shot every time I get up on my soapbox:
If the computer has set a misfire code, please be aware "misfire" wasn't the best terminology that could have been used. Misfire sounds like an ignition problem, at least to me, meaning the fuel and compression were there, but for whatever reason, the required spark was missing or weak. This might lead an aspiring mechanic to troubleshoot the daylights out of a perfectly good ignition system. I do not care to discuss how I know this.
In OBD-speak, misfire simply means one or more cylinders is putting out low power compared to the others. Pretty much anything affecting the output of a cylinder can set a misfire code. It can be low compression. It can be a valve not opening fully. It could be a clogged fuel injector. And yes, it could be an ignition problem, too, but don't overlook the other possibilities, too. [/soapbox mode off]
One last thing. When did this problem start? Was this after some other recent engine work? Out of the blue?
Re: #5 coil that was replaced. Some brands have dismal reliability. I'd suggest swapping it with a known-good coil from another cylinder. Sometimes parts are bad right out of the box. Don't assume any part is good just because it's new.
So as a driver trying to avoid fastfood i used to cook frozen healthfoods on my engine while i drove and by lunch it was ready however the shaking seemed to be whenever i had food cooking and would stop when it wasnt. So i replaced the coil but it didnt stop but minimized. But came back. I ran some bg44k and it seemed to start again now its full on misfire. Sprayed for vacuum leaks didnt change idle at all. Leaning towards low fuel pressure. Leaking injector or clogged filter but like i said i blew air through it fine but am replacing it anywayin two days. And yes i fear the worse but i have to drive it or i have no money so fingers crossed i hope to get it it fixed before ita too late.now i have bank one too rich bank 2 too lean.
Unfortunately, that's not a valid test with electronic fuel injection. The computer will quickly adjust the fuel to maintain a steady idle. The RPM typically won't vary much at all. You have to watch the fuel trims on a scanner to see the response to spray at a vacuum leak.
Don't know what to suggest with your observation about cooking food. Maybe condensation from the food thawing was affecting one cylinder?
The computer is trying to be nice to you, doing all sorts of stuff behind the scenes to get you home where you can properly troubleshoot the situation. It's keeping notes for your benefit and doing its darndest to prevent engine damage. The engine would be VERY cross with you if it found out you are continuing to drive everywhere without the slightest hint of basic diagnostics such as compression test and a cooling system pressure test.
SOLVED
Yup head gasket. Put some bars pro head seal and no more back pressure of gasoline in coolant. Misfire was a dead cpil. Car is back ip and running better than ever since i bought it. Now 233000 miles and going strong like new now for some cosmetic restoration! I think ill keep. Cpild use a new drivers seat though.
kr98664 (07-03-2019)
05-03-2023 08:44 AM
Bills
03-30-2022 08:02 AM
MattSteele
09-02-2014 11:11 AM
philhef
07-12-2014 01:49 PM
