Alarm backup battery replacement
My alarm backup battery located on the firewall hasn’t worked for a while, so as I’ve finished work for Christmas, I thought I’d remove it and check the part number for ordering a new one.
The part number is “6G9N 19G229 DE”, but I can’t find anybody selling new ones, only used ones on eBay which I’m not interested in.
Does anybody know where I can purchase a NEW replacement from, my car is a 2006 4.2 XK?
Are you talking about the whole alarm unit. The battery is inside and not a FRU.
The siren unit is the same as Ford Fiesta which you can get new at a reasonable cost. I got a new one off EBay a couple of years ago.
In the UK the siren and beep /double beep which uses the Sounder is programmed OFF. So generally you don’t get a sound when locking the car.
I knew my battery had failed as I was getting a Geiger counter sound at various times even when the car was locked.
This sounder unit is permanently connected and can flatten the main battery if faulty.
In other countries the sounder is programmed ON
My main battery in the boot started discharging over the course of a week and by checking fuses with an ammeter and removing them, I narrowed it down to the alarm sounder backup battery. When I removed the backup, I prized it open and found it full of water and totally corroded.
Yes, I've had that "beep" turned off. Flashing lights do me fine. But I was under the impression that the alarm was powered by the car battery??
Congrats on finding the problem!!!!
Can anyone show specifically where in the car I can find this?
On a RHD car. It’s on the firewall under the RH bonnet release unit.
You have to move the explosive Device to get to the holding bracket.
Its a bit fiddly but very doable with a bendy socket set.
I assume on a LHD car it’s on the left side but could be wrong
A more detailed explanation with pictures is on here so worth search on Sounder
As per the photos above, mine was in a similar mess - just get a used sounder from another Jag and use that - forget wasting your time trying to replace the battery - no you dont need to program it
To replace the sounder in my XK it's around an hour, maybe a bit more as it's a bit of a faff due to no room in the firewall area. The sounder makes a distinctive beep when armed, and obviously sounds if the vehicle is intruded upon or jacked up so worthwhile replacing. It's not worth repairing the old unit, they aren't expensive and they are used in many vehicles including Volvo so you don't need to think this is a unique Jaguar part, like most of the parts on a Jaguar they are made to accommodate many vehicles just as the fuel pressure sensor and lot's of more parts.
The only thing to be mindful of is the holding bracket needs to have the screws in the correct place, so I got a used one from a different Jag no idea what model it was but it wasn't a XK and it fitted fine
I did this so learn from my fail make sure battery is disconnected before removing the bonnet air bag otherwise you get permanent error on the dash because it believes the air bag deployed. If this does occur you can get the bypass units of ebay and solder them in to make the circuit to remove the dash light else it would be MOT failure or expensive trip to dealership
