Heater valve is working opposite what it should
Old Mar 22, 2026 | 05:10 PM
Dave Neuhaus's Avatar
Default Heater valve is working opposite what it should
The heater valve opens when vacuum is applied and closes with no vacuum. Per other posts the opposite should be true.
My car is a low miles 1992 XJS. The valve appears to be original. I have no heat until I manually apply vacuum to the valve.
Is it possible that something slipped in the valve or is it different for 1992?
Here are images that I have borrowed from another post that illustrate how it is supposed to be.
This is how it is said to work, but my car is the other way.
Old Mar 23, 2026 | 03:29 AM
NO vac is wide open.
VAC is closed.
BeEn that way on Jags since S2 and S3 and XJS since inception. 1992 is as described..
Old Mar 23, 2026 | 10:32 AM
I've removed the valve from the car and discovered that it indeed self-reversed its function. It slipped internally. With the help of a screwdriver I was able to move the drum inside to the intended position.
A new one is on order.
Come to think of it, this slippage could cause the valve to be partially closed.
So if your car does not heat very well it might be worth looking into.
Partially open with the AC on would also affect cooling performance.
Old May 18, 2026 | 02:29 PM
So I replaced the valve with one from eBay, but the new part was leaking fluid, a lot of fluid.
Then I bought an expensive one from another supplier that looked slightly different. It leaked so much vacuum that it would not function.
2 bad valves right out of the box. It appears that only made in China valves are available.
Vee (member) says that this plastic valve is superior. Third times the charm, hopefully.
"Four Season 74803"
Old May 19, 2026 | 01:40 AM
Greg in France's Avatar
"Four Season 74803"
This is an increasingly serious, problem. Aftermarket parts for our cars arefrequently poor quality. Any genuine NoS OEM parts you can find, either new or in good second hand condition, are worth buying.
Old May 19, 2026 | 10:18 AM
AZDoug's Avatar
Aftermarket, made in China usually, parts are a problem for ANY older car.
As far as most Chinese manufacturers are concerned, if it looks like an original part, it is as good as an original part, the actual function or longevity doesn't matter.
Doug
Old Yesterday | 02:00 AM
Vee's Avatar
Vee
I can confirm, plastic part works great…. Pot metal aftermarket parts leak right out of the box more often than not. Stick with the Four Seasons if replacing
Imono12345
Nov 22, 2023 12:39 AM
petemohr
Dec 1, 2021 08:14 PM
yachtmanbuttson
Apr 3, 2020 01:06 PM
twncty
Aug 4, 2014 02:11 AM
Don S-Type
Dec 7, 2012 12:10 PM
