Generally accepted point of failure is the plastic elbow that connects the thermostat to the water pump. Thought the brass replacement might be the solution but 20,000 miles after changing out the elbow with the kit from RKX which includes a new O ring seal and plastic keeper/release I now have two motors with pretty good leaks at the brass elbow where it goes into the water pump. I know people who tried the aftermarket complete metal pipe kit have had problems with the aftermarket O ring seals. I'm thinking this little seal might be a similarly weak link. I have a couple new kits coming via Amazon but wondering if I can match up the O ring seal with something more durable. I don't think the factory seal is available without an entire water pump attached?
That’s the kit I’ve been buying. The brass elbow is obviously more robust than the factory plastic one but it seems the supplied O ring is not as robust as the factory O ring. Wanted to know if ya’ll had similar experience and found a solution. The aftermarket O ring kits are not helpful, the O’s aren’t as thick.
I would take the o-ring out and measure it, then order something higher quality via mcmaster or somewhere. I was looking into that for the I6 turbo coolant lines before they launched the updated parts. We had dozens of customer cars down at the store with no parts, and I could have ordered a more robust o-ring for $15/100.
New O ring from replacement kits I ordered miked out at 10mm OD, 5.5MM ID and 2.25MM thick. Found an O ring on McMaster that matched and ordered the most heat resilient version. I’ll try them out this weekend.
It's a bit hard to tell from the photo but it looks like the brass elbow is a right angle while the plastic one is greater than 90 deg ?
Just wondering if that is the case the O ring may not be completely sealing on the spiggot as it's on an angle to the water pump receptacle ??
The photo is deceiving, The angle of the brass elbow is the same as the plastic one.
In both of my effected motors, the brass elbow is not fitting as tight as it did when first installed.
We tried an O ring from an assortment kit my tech had but the fit was way too loose.
I broke the plastic elbow when doing my water pipes upgrade, bought a brass version but did not like the way it fit (too loose indeed).
In the end I went full OEM and bought the WP to get a new o-ring and female bit, and a thermostat pipe to get the OEM elbow.
Another option is to get the brass version and use coolant-rated sealant. Probably a surefire to do this but you'll need to drain a lot of your coolant to get the mating surface dry.
Ran to my dealer in the valley and grabbed the hose with the plastic elbow. Just in case. Plastic elbow mikes out a tiny bit smaller than the brass version.
Received the McMaster O rings.
Sucked about a gallon of coolant out with my M18 Packout vacuum when releasing the elbow. Swapped out the O ring.
Had a heck of a time getting the intake Y pipe back on the throttle body. Wish I knew the secret for making that a bit easier.
Ran the motor. No leaks.
Super Cleaned the motor and took it for a warm up drive and bath. Now to let it cool down and check the final coolant level.
Heat it up with a heat gun. Just warm to the touch, softens the plastic, it slides right on.
Did the second one after work. Went smooth, about 15 minutes front to back. Heat gun trick worked a charm. Thought, jeez, I’m getting pretty good at this. Then I broke the overflow hose at the radiator while wrestling the port intake hose in place. 🤦♂️
when purchasing the brass elbow never ever use the seals provided, just pop the elbow into the water pump and that's it, I've
done over 30 or so of members with no issues
