This one is kind of a mystery, and at this point, Im honestly a little confused and would love to hear some opinions. I tried to explain everything clearly below because I feel like I may be overlooking something. Originally, I replaced the transmission and torque converter because my car had been throwing a P0740 code for a few months. Then one day, while making a left turn, the car suddenly stalled and came to a hard stop in the middle of an intersection. It made a loud clicking/ratcheting sound that almost sounded like Park trying to engage while moving. After that, the car would not move. I talked to a lot of people and read a lot of posts, and almost everyone said that P0740 usually points to a bad torque converter. Since I was already planning to replace the converter, I decided to install a lower-mileage transmission at the same time instead of replacing only the converter. I installed a complete transmission, torque converter, and donor mechatronic from another XJ with around 48k miles. What has me confused is that Im still getting P0740, and now Im also getting P2764. I know anything is possible, but it would seem pretty unlucky if both torque converters happened to be bad, so Im starting to wonder if something else is actually causing this, maybe even electrical, or if the new transmission TCM is a replacement, do I need to configure it in SDD?
Vehicle:
2012 Jaguar XJ (X351)
5.0 Naturally Aspirated
ZF 6HP28
Original issue:
The original transmission had a persistent P0740. The car actually drove mostly normally for a while. Then one day, while turning left, there was a loud clicking/ratcheting sound that sounded almost like Park trying to engage while moving. The car stopped abruptly and would no longer move afterward, which is similar to what the car is doing right now.
Replacement setup:
Installed transmission and torque converter from a 2013 XJ (~48k miles)
Opened transmission only to replace:
Filter
bridge seal
cylindrical/mechatronic seals
connector sleeve seal
Used correct ZF seals
Followed the ZF torque sequence carefully
Did not disassemble valve body
Did not remove individual solenoids
Current symptoms:
The car starts and drives, but shows that it has a gearbox fault.
Transmission engages gears somewhat normally, but p0740 and p2764 don't disappear. P0740 does for a minute if I clear the codes, but comes back pretty quickly.
No major shudder
No major slipping
No major harsh shifts
Shifts may feel slightly elevated, but nothing dramatic.
Important behavior:
P0740 seems to remain stored consistently
P2764 only appears after revving the engine to around ~4000 RPM
Sometimes reverse works, but sometimes when I put it into reverse while I'm backing up, it will suddenly stop, and I can't hear the parking pawl clicking into position.
Verified:
Transmission fluid level checked multiple times and appears correct using Pentosin ATF6
The charging system confirmed good
Transmission module voltage while running is normal
Current transmission DTCs:
P2764 Torque converter clutch pressure control solenoid control circuit low
Intermittent U0402 / invalid data received from transmission control module after transmission faults.
My question:
Most Jaguar techs Ive talked to say P0740 almost always ends up being the torque converter.
But:
I now also have P2764--Torque converter clutch pressure control solenoid control - circuit low
P2764 appears conditionally (mostly high RPM)
Does this sound more like:
Am I the one in a million that actually has a dead TCC solenoid, which is causing P0740?
Donor mechatronic issue?
Since it's showing up in both transmissions, is it possibly a software or even an electrical harness issue?
Trying to decide whether to:
Replace solenoids?
Replace mechatronic?
Pull the transmission again for the converter?
Investigate wiring/configuration first?
Would love to hear from anyone with actual X351 / ZF 6HP28 experience! Besides this major problem, the car is running great and I would genuinely appreciate any advice or someone who has experienced this before. Thanks for everything, and I look forward to hearing any feedback!
Was the replacement TCM coded to your car using SDD? I think that is required. Or did you swap the old TCM into the replacement transmission?
With the replacement being a 2013 there might be differences between that year and your 2012.
No, I didn't program the TCM to the car, and the more I think about it, the more it makes sense. Also, since a few modules were showing invalid data and so on from the TCM, I'll make sure to do that shortly and see what happens. The valve body was from the donor transmission, and if I remember correctly, it was either a 2011 or 2013, so not the same year. I won't have time to work on the car for about a week, but I'll let you know what happens. Thanks!
Good luck with the reprogram, once the TCM has a VIN in it, it doesn't like to play nice with the rest of the car sometimes.
I would say, I would test the circuit for the TCC solenoid before going any further. If you can rule out the actual wires/solenoid/driver, you might solve your issue.
I would start here, with power/ground voltage drop testing. If you have a poor ground and it's causing the TCM to not have correct control over the solenoids, that would make sense that your issue is the same despite the new trans, as that's something you didn't change.
That sounds great, and thank you for taking the time out of your day to look up the diagram. In addition to the transmission, I also swapped the engine and harness about two years ago. So, since I messed with the harness and ECU connectors, I'm going to go back through everything and see if there's a pin or wire in that diagram that could be causing the issue. I honestly have no idea why I didn't think about the possibility that the TCU might need to be programmed to the car. It seems that I may have solved one problem but created another, haha. It's been a rough week. Regardless, my plan now is to check the wiring first, then move on to re-flashing the TCM with the stock SDD file. If that doesn't fix it, I'll find a company that can virginize it and get the car roadworthy again. You guys are awesome, and I really appreciate all the help!
