air suspension
2004 xj8 i put a t valve between the air tank and block valve and aired system up to 160 psi, drove car for 15 minutes and suspension didn't raise. did not lose any air, pressure still the same. can anyone help me out on this?
You might want to ask your question in the appropriate sub-forum for your Jaguar model:
https://www.jaguarforums.com/forum/x...-x350-x358-28/ You have posted in a regional forum which is not very active. A post introducing yourself in the New Members forum is usually expected as the above post appears to be your first. Good luck solving your problem! JR |
i have 2 2004 xj8, the suspension i guess has dropped. my rear tire is on flat once the suspension went down. the tire is still on flat. do you think when i air the tire the car will rise a litte?
