x type engine code p0430
Shortly after buying my 2003 x type 2.5 the engine malfunction light came on. The local mechanic says the diagnostic code that comes up is P 0430 which I was told is a bad catalytic converter. At first they said they thought the code was for a bad oxygen sensor. When I tried to get the car inspected it failed because the OBD was not ready. I have seen a thread about bad cats and I am hoping someone can tell me for sure if this code means a bad cat converter.
thanks
Howard
2003 silver x type 2.5
thanks
Howard
Received 3,824 Likes
Howard, the code indicates that the cat is seen as not being efficient enough. This can be the result of either your cat not working like it should (ie, coated with foreign material) or one of your O2 sensors is not reading as it should (coated with something or simply failing, but not to the point that it is triggering the O2 sensor failure). If you have a scanner that you can get real time data from, that will tell you whether your cat or the sensor is bad. If not, you can either buy a scanner or you will need to stop by a shop that can read the data and then tell you what is going on.
thanks
Howard
thanks
Howard
Thanks. This is very helpful. Hopefully it is just the oxygen sensor. The weird thing is the engine malfunction light is now out. But I need to figure this out so the car can pass inspection
I have a P0420 - which is the same exact problem BUT on the firewall side ... which means it's even more of a PIA
Hope it's just the O2 sensor for you too. g/l
Is there any way that someone could have unplugged the O2 sensor at the connectors and inadvertently plugged the grey one where the black one should be and the black one where the grey one should be, or will they only fit in a each particular spot ?
Wa3ra had a possible solution on a recent similar thread. He recommends checking the fuses for the 02 sensors to make sure they are not blown. He had a similar problem and simply replaced a blown fuse to resolve the issue.
It may not be your problem, but worth checking and easy to do. (see attached)
myexcursion (07-16-2014)
philwarner
12-06-2021 07:13 AM
X_Type_South_Africa
12-09-2015 05:37 PM
stanjag
08-30-2015 10:35 AM
NinoGrimace
08-26-2015 05:15 AM
