03 x type doors panels
I had the same problem on my 02 x type with a blown speaker. What you first have to do is buy a speaker. The easiest type to buy is a 6.5" 4-way sony xplod because they fit in the doors with just new holes. As for getting the door panels off, there are 3 physical screws and the rest are clips. There are two screws located on the bottom of the door panel and there is one in the middle of the panel which is covered over by a little round piece of plastic. Once you get all three screws out you will have to pull the door panel off completely straight. If you pull it off crooked you will break the plastic clips and also the mounting point where the clips mount onto the back of the door panel. 9 times out of 10 you will break a clip or two in removing the door panel, but new ones can be ordered off of ebay and similar places. Let me know if you need any help!
Received 9,005 Likes
check the X type quick FAQ link thread.......there's a link there and a post c/w pics and a write up
Step by step door panel removal! - Jaguar Forums - Jaguar Enthusiasts Forum
stanjag
08-30-2015 10:35 AM
