04 X-Type 3.0
04 X-Type 3.0
Just found a cheap simple way to repair imt valves that leak air 0n xtype's.the repair according to jag was to remove the upper intake remove both valve and replace with the factory seal.well I found that u can leave the intake on by putting seal over the valve.it will stretch(lower)..but the best thing I didn't use the factory seals.i went to local parts guy and used the seal that come from a cartridge type oil filter that had an inside diameter of aprox 60.5 mm slightly off size will work cost me nothing and 10 mins of my time.
Do a quick search on here about that. There are plenty of threads and pictures about them and how to change them out. Simple, cheap and easy to do.
11-30-2006 11:15 AM
