2.5 auto trans issues.
Old May 5, 2017 | 12:00 PM
Brandon Crespo's Avatar
Default 2.5 auto trans issues.
My 02 X Type 2.5 automatic has not in shifting smoothly, it shifts rough into 1st and 2nd occasionaly and usualy hesitates shifting into 3rd. I'm planning on changing the transmission fluid with fuchs 4400 titan atf tomorrow. I just put it on the lift at my body shop and noticed a vacuum hose that looks to be disconnected not sure if that could be the culprit there are no lights on the dash and I have yet to been able to check for codes with a computer I hope it's not too serious.
Attached Thumbnails 2.5 auto trans issues.-20170505_121059.jpg   2.5 auto trans issues.-20170505_121104.jpg
Old May 5, 2017 | 03:23 PM
Rchiv's Avatar
That looks very much like the battery vent pipe. How do you know it is a vacuum pipe.
Roger
Old May 5, 2017 | 05:50 PM
swingwing's Avatar
Bet you're gonna find not much fluid drains out, and what does is going to look and smell like crap. Not to worry though - it's "lifetime fluid." Jaguar's (as well as many other OEMs) desire is that you'll come to them for replacement of a transmission (and/or transfer case, differential) that's lifeless. Jes' sayin'.
Old Sep 3, 2019 | 03:31 AM
JagQ's Avatar
How did Titan ATF 4400 work for you ?
I am looking at the bottle and it does not say synthetic on it !!
here is the print on the bottle
FUCHS Recommendations
DEXRON III
AISIN WARNER / AW-1
BMW MINI 83 22 0 402 413 / 83 22 7 542 290
DAEWOO
DAIHATSU ALUMIX ATF MULTI
FIAT TYPO T-IV
FIAT 9.55550-AV4
FORD MERCON / M2C924-A / M2C922-A1
GM 9986195
HONDA ATF Z-I
HYUNDAI SP III, SP IV
ISUZU BESCO ATF-II/ATF-III
JWS 3309/TYPE T-IV
KIA SP-IV
MAZDA ATF D-III/ATF M-3
MITSUBISHI SP-II/-III
NISSAN MATIC C/D/J/S
SAAB 3309
SUBARU ATF OIL/ATF OIL SPECIAL/ATF HP
SUZUKI ATF 3309/3317
TOYOTA TYPE T/T-II/T-III/T-IV
TOYOTA TYPE D-2/WS
VW G 052 990 / 055 025
JATCO 3100 PL085/FWD(N402)/JF506E(K17)
CHRYSLER ATF +3 / +4
is that suitable for x type ?
Old Sep 3, 2019 | 06:00 PM
Dell Gailey's Avatar
Jaguar x type requires meeting "indemitsu k17". I see that Jatco506E(k17) (our trans) listed on your post. I assume that is correct. You can debate mfgs all day long (red line, Valvoline, Castrol, etc.). In the end the spec (indemitsu k17) is all that matters.
Fuchs is not a synthetic, it's comparable to the older Marcon III type.
Marcon 5 DOES NOT work in our Jags.
I used Castrol IMPORT (note import) Multi-Vehicle ATF for my change which is a synthetic blend BUT has a viscosity rating of 200. It's been great.
Old Sep 3, 2019 | 07:08 PM
Yorta2's Avatar
If his car is still going after 2 1/4 years of driving with that fluid, then I would guess it was okay (but I'd be really surprised)....
Old Sep 4, 2019 | 08:31 PM
JagQ's Avatar
https://www.adenstyres.co.nz/product...full-synthetic
what do you make of that ?
Old Sep 10, 2019 | 08:38 AM
bytjies's Avatar
JAGUAR X-TYPE EXECUTIVE 2008 MODEL
Can I use Castrol Dex 6 in the Tranny? having a issue to get the correct oil.
Old Sep 10, 2019 | 02:20 PM
If a fluid (any brand) DOES NOT list it meets indemitsu k17, DO NOT use it.
I don't see the correct type listed on their spec sheet, so I would not use it.
Old Sep 11, 2019 | 12:25 AM
bytjies's Avatar
What about Castrol Transmax™ Import Multi-Vehicle Automatic Transmission Fluid (ATF)
Old Sep 11, 2019 | 01:11 AM
bytjies's Avatar
I just found the perfect oil with that approval: Caltex Havoline Multi Vehicle ATF. And it is really affordable too.
F-Pace (X761) / C-X17
20
Mar 5, 2026 09:20 PM
SteveSheldon
UK & Eire
234
Sep 20, 2018 04:52 AM
Oct 31, 2012 11:05 AM
pdowning6
Mar 23, 2010 11:32 PM
Dennis
Apr 28, 2009 06:37 PM
