2003 X-Type
my 03 wont turn over the battery is fully charged, i can jump across the seloinoid and it will turn over but will not start, any ideas ,and i did try putting it in neutral still did nothing
Welcome to the forums russ1771,
I've moved your question from General Tech Help to X-Type forum. This is the place to post questions about your model. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
Auto, manual, any lights? Use an OBD and pull codes, look them up in search function in this forum (change search box to "X type only").
When you turn key to position 2 (just before start), does the m.i.l. (engine icon) remain lit or extinguish? Is the PATS light blinking? If so it will blink (after like 30-60 seconds) a series like once, then 3 times or something along those lines? |
Okay, how about a little history, the genesis of the problem.
My experience compels me to ask, does the message center show anything? Or is it just dashes. It is possible, the PATS lights to extinguish, but check with the message center in the dash, it it displays only dashes,then it wont turn over, it is definitely a CAN issue |
Dealer mechanic told me, instrument clusters die all the time and showed me box of dead clusters. This is what happened to my S.
PATS module is in clusters. If this is your problem, $100 used cluster, $100-150 programming. + towing |
^^ yup a "dealer mechanic" showed you a BOX full of bad clusters!! You'd lie if the truth sounded better.
If a "dealer mechanic" showed you a box of used clusters, the "dealer parts guy" would be all over his ass for the core returns.
If it happened to begin with. |
