2K2 X-TYPE Issues
Peace and Greetings to all my fellow JAG dudes and dudettes; I've just pruchased a used JAG 2K2 model, it had 32kmls on her whne I purchased her in July. Since then there have been instances of the "Engine malfunction light" sporadically coming on. I felt it was just do to the car maybe sitting for a while at the dealers. But now it's really acting up. I have a power sterring leakage, that I can only see it leaking from beneath the body, no hoses on eitherside of the PW steering depository seem to be leaking so it has to be something beneath, loose or cracked. Also I 'm getting the gearbox fault error message, which seems to slip the tranny at times. I'm trying to find a reputable repair shop without going to the dealer who I know is gonna take have of both my legs to pay for something that may be simple. I am trying to get uner the car to see if I can truly locate the leakage and maybe fix it myself. Any clues, I currently have 44k mls on her, and I know she is do for full maintenance overhaul accroding to the docuemntation in the OWNERS manual. Any other clues or tidbits... Thanks and hope to hear from youa ll sonn. :-)!!!!!!
RE: 2K2 X-TYPE Issues
call jaguar direct and find out the exact date your car was put into service. they all come with a 4 year / 50k mile bumper to bumper warranty. you may be lucky. if it is close to the expired date, try talking to a local dealer and see if they can help you out, or even jaguar themselves. on my last suv, a suzuki, i was out of my factory warranty by 3000 miles and they still honored it for me after making a few phone calls.
Thanks nienball, I really appreciate this, I will let you know what works out! Only thing was I baought it from a secondary dealer, does that matter, if I didn't buy it directly from Jaguar?
Here is the procedure to evaluate whether the Jaguar's diagnostic system has picked up a reason for the the check engine light (copied from the UK Jaguar forum - I've never tried to do this myself):
You hold down the computer button (on the end of the left hand stalk) whilst turning on the ignition. You can then step through all the codes that are being sensed at the time by single presses of the stalk. All OBDII codes and their meaning. Good for all vehicles 1996-2007 (yes, even X type) P0100 Mass or Volume Air Flow Circuit Malfunction P0101 Mass or Volume Air Flow Circuit Range/Performance Problem P0102 Mass or Volume Air Flow Circuit Low Input P0103 Mass or Volume Air Flow Circuit High Input P0104 Mass or Volume Air Flow Circuit Intermittent P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent P0109 Intake Air Temperature Circuit Malfunction P0110 IAT Circuit Malfunction P0111 Intake Air Temperature Circuit Range/Performance Problem P0112 Intake Air Temperature Circuit Low Input P0113 Intake Air Temperature Circuit High Input P0114 Intake Air Temperature Circuit Intermittent P0115 Engine Coolant Temperature Circuit Malfunction P0116 Engine Coolant Temperature Circuit Range/Performance Problem P0117 Engine Coolant Temperature Circuit Low Input P0118 Engine Coolant Temperature Circuit High Input P0119 Engine Coolant Temperature Circuit Intermittent P0120 Throttle Position Sensor/Switch A Circuit Malfunction P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem P0122 Throttle Position Sensor/Switch A Circuit Low Input P0123 Throttle Position Sensor/Switch A Circuit High Input P0124 Throttle Position Sensor/Switch A Circuit Intermittent P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control P0126 Insufficient Coolant Temperature for Stable Operation P0128 Coolant Thermostat Malfunction P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1) P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2) P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2) P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3) P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3) P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3) P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3) P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3) P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3) P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1) P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1) P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1) P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1) P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1) P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2) P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2) P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2) P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2) P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2) P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3) P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3) P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3) P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3) P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3) P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3) P0170 Fuel Trim Malfunction (Bank 1) P0171 Fuel Trim System Lean (Bank 1) P0172 Fuel Trim too Rich (Bank 1) P0173 Fuel Trim Malfunction (Bank 2) P0174 Fuel Trim too Lean (Bank 2) P0175 Fuel Trim too Rich (Bank 2) P0176 Fuel Composition Sensor Circuit Malfunction P0177 Fuel Composition Sensor Circuit Range/Performance P0178 Fuel Composition Sensor Circuit Low Input P0179 Fuel Composition Sensor Circuit High Input P0180 Fuel Temperature Sensor A Circuit Malfunction P0181 Fuel Temperature Sensor A Circuit Range/Performance P0182 Fuel Temperature Sensor A Circuit Low Input P0183 Fuel Temperature Sensor A Circuit High Input P0184 Fuel Temperature Sensor A Circuit Intermittent P0185 Fuel Temperature Sensor B Circuit Malfunction P0186 Fuel Temperature Sensor B Circuit Range/Performance P0187 Fuel Temperature Sensor B Circuit Low Input P0188 Fuel Temperature Sensor B Circuit High Input P0189 Fuel Temperature Sensor B Circuit Intermittent P0190 Fuel Rail Pressure Sensor Circuit Malfunction P0191 Fuel Rail Pressure Sensor Circuit Range/Performance P0192 Fuel Rail Pressure Sensor Circuit Low Input P0193 Fuel Rail Pressure Sensor Circuit High Input P0194 Fuel Rail Pressure Sensor Circuit Intermittent P0195 Engine Oil Temperature Sensor Malfunction P0196 Engine Oil Temperature Sensor Range/Performance P0197 Engine Oil Temperature Sensor Low P0198 Engine Oil Temperature Sensor High P0199 Engine Oil Temperature Sensor Intermittent P0200 Injector Circuit Malfunction P0201 Injector Circuit Malfunction - Cylinder 1 P0202 Injector Circuit Malfunction - Cylinder 2 P0203 Injector Circuit Malfunction - Cylinder 3 P0204 Injector Circuit Malfunction - Cylinder 4 P0205 Injector Circuit Malfunction - Cylinder 5 P0206 Injector Circuit Malfunction - Cylinder 6 P0207 Injector Circuit Malfunction - Cylinder 7 P0208 Injector Circuit Malfunction - Cylinder 8 P0209 Injector Circuit Malfunction - Cylinder 9 P0210 Injector Circuit Malfunction - Cylinder 10 P0211 Injector Circuit Malfunction - Cylinder 11 P0212 Injector Circuit Malfunction - Cylinder 12 P0213 Cold Start Injector 1 Malfunction P0214 Cold Start Injector 2 Malfunction P0215 Engine Shutoff Solenoid Malfunction P0216 Injection Timing Control Circuit Malfunction P0217 Engine Overtemp Condition P0218 Transmission Over Temperature Condition P0219 Engine Overspeed Condition P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent P0230 Fuel Pump Primary Circuit Malfunction P0231 Fuel Pump Secondary Circuit Low P0232 Fuel Pump Secondary Circuit High P0233 Fuel Pump Secondary Circuit Intermittent P0234 Engine Overboost Condition P0235 Turbocharger Boost Sensor A Circuit Malfunction P0236 Turbocharger Boost Senso |
Can I purchase any OBDII scanner and hook it up to the Jag for diagnostic purposes or does it have to be a particular one?
I don't know. In the old days (1990's) there was a connector at the rear L/H of the engine bay to hook up the diagnostic system to. I get the impression that the codes are standard, and my guess is not just limited to the Ford empire, but common to GM and DCX as well.
But look again at the UK forum's instructions - it appears that you can do the diagnosis from the driver's seat using the controls there, implying that you don't have to buy anything. It may be worth confirming this with a dealer or just by trying it yourself. |
it should not matter. i was the second owner of my x, and i bought it from a non-jaguar dealer. i called to register as the new owner and found out the original buyer also purchased the extended warranty up to 75k miles, which was a nice bonus. it transfered to me without a problem.
The vehicle (to my understanding) is covered as long it is under the year and mileage. You can also purchase the extended warranty through jaguardirect to get a warranty that covers 6 years and 100,000 miles. Check into it man as it is a bumper-bumper warranty and is the same as the original warranty that comes with it. All you have to be is under the original warranty to buy this one and it only costs $2500 dollars. To me it is worth it 1000% full! I looked into getting a warranty for mine and they are all $3-$5k!!! By the way this warranty is directly from jaguar which means you take it to the jaguar dealer to work on and there is no deductible!
I was offered a Warranty extension by a Jaguar dealer (from the original 4 year 50000 miles to 6 year 100,000 miles) for $1600. I get the4 impression that the price is flexible.
Man you lucky son of a stick! When I called to find out how much it would be if the factory warranty was in tact the dude said it would be 2500. Not a deal though for 1600! First driveshaft costs $1082 just for the driveshaft! Just had mine replaced under powertrain warranty! I'd imagine that the driveshaft would have costed me about 1200-1500 out the door so 1600 for the factory bumper to bumper is a bargain especially cuz ur covered to 100k. Good to hear you save so much money over buying the car at a jag dealer! I was talking to a guy up at jag of troy by name of keith burch and their cars were over 5k what I could get them anywhere else. Which means they were charging about 3-4 grand just for the warranty that only cost you freakin' 1600! The cars at a jag dealer are mostly lease and the people took much better care of them though. So what did you end up getting?
[>:] At least you guys got a chance to buy extended warranty. I got my Jag with over 51K...so now no one wants to cover it at all!
| All times are GMT -5. The time now is 09:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
