ABS
Old 08-17-2017, 09:17 AM
Travers's Avatar
Default ABS
hi I have a 1998 XJ8. can anyone tell me if having the brake pipes renewed would cause the abs ,traction and stability faults to appear. I have replaced the abs sensor. The code wont clear with diagnostics. nopower from sensor to cpu ? unit. might this be a cable fault?
Old 08-17-2017, 09:36 AM
Received 7,872 Likes on 4,759 Posts
You need to post in the X308 section of the forum.
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
More help from the people that own/repair these cars.
You will also need a more specialized diagnostic device to read C codes from the ABS module.
bob
Old 08-27-2017, 05:27 PM
GGG is offline
Received 16,788 Likes on 12,163 Posts
Welcome to the forum Travers,
I've moved your question from X-Type to X308 forum. Members here with the same model will be able to help.
Old 08-27-2017, 07:28 PM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
What code do you have? There are quite a few refering to the ABS and all have to interpretated differently...
quartetchiang
02-12-2017 07:36 AM
bullittandy
02-06-2017 09:35 AM
blackonblackXtype05
01-11-2017 10:45 PM
wymjym
01-05-2017 02:23 AM
JagXV6
06-09-2013 06:51 AM
Quick Reply: ABS
