Blue/green blue 2 way connector behind battery
After changing the battery on my x type I noticed a two wire connector with blue/green and blue wire which was not connected to anything. Thought it might be the connector for a water coolant level sensor but but doesn't seem to fit into the bottom of the water coolant expansion tank. No warning lights on dash. If it doesn't go to the water level sensor where does it go ? Do I need to worry about it or is it redundant wiring.
I think you'll find it is a transit connection for the battery used during initial delivery.
There should be a dummy connection on the battery box for it to clip into. Look here https://www.jaguarforums.com/forum/x...esolved-81368/ |
Originally Posted by Norri
(Post 613204)
Hey thanks for the swift reply guys, at least I know its nothing to worry about.
