brake fluid issue
Old Jan 9, 2015 | 11:01 AM
dig5438's Avatar
Default brake fluid issue
The rear brake lines corroded & failed on my X type, so I replaced them both & while trying to bleed them ( 2 person method, 1 on the pedal & me at the nipple) , I can't get pressure at the calipers. Any ideas?
Old Jan 10, 2015 | 07:12 AM
dig5438's Avatar
Just an update incase this happens to anyone else. I checked to get pressure at the ABS unit & managed to get pressure after a lot of bleeding at one of the feed lines(front left & rear right feed) but nothing to the other line, so checked the master cylinder & was only getting pressure through 1 port, so got a new master cylinder. I fitted this & had the same problem. I removed the master cylinder & checked the servo & found this had collapsed. So new servo needed. Apparently this is not uncommon on Ford Mondeos when the fluid is all lost due to leakage or master cylinder failure. Thanks for taking the time to look.
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
obwoodie
Sep 3, 2015 07:45 PM
