broken key help
Old Nov 18, 2010 | 02:18 PM
helio323's Avatar
Default broken key help
i broke my key. i bough a another key on ebay for 20 bucks. i want to swap the housing of the remote. has anyone try to swap the housing. any ideas will be great. for right know i start the car with a rench holding the key and puting the remote close the the rench so it can start.
Attached Thumbnails broken key help-imag0029.jpg   broken key help-imag0028.jpg   broken key help-imag0026.jpg
Old Nov 18, 2010 | 02:27 PM
Pete04xtype's Avatar
The alarm housing and key housing come apart so they are 2 separate pieces. Looking at my key now it looks like the broken piece would be able to be pryed away so a new one could be put in.
Old Nov 18, 2010 | 03:11 PM
helio323's Avatar
the remote is on its way from ebay. i never try to open the key. what tools do you need to open the remote
Old Nov 18, 2010 | 04:31 PM
exrub's Avatar
Ouch! That sucks!
To separate the key part from the alarm part, you need a small screwdriver. Turn the fob over so the buttons are facing your palm. You'll see a little notch on the back side. Insert the small screwdriver and PUSH the upper part (key part) out. DO NOT TRY TO PRY THAT PART UP AS IF YOU'RE OPENING A LID!
Now, the key blade swap, I can't help you there. I would think the round button to release the key must go in further to remove the blade or something since it's spring loaded. Sorry!
Good luck!
P.S. You do know that you'll have the get the key cut and programmed, right?
BadKat174
May 26, 2023 12:29 AM
peterg19
Feb 10, 2023 09:02 PM
JWheeler
Nov 22, 2019 08:28 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
