Broken Wheel Stud
How do I remove a broken wheel stud from the front driver's side of my 2007 Jaguar Xtype 4dr sedan?
The wheel cannot be removed because of the broken stud. |
Remove hub, brace well, pound out old stud, replace stud, fit into place by snugging tight with the nut.
Lincoln LS are same studs @ lower price usually. |
Broken Wheel Stud
The wheel cannot be removed. Can it be drilled out?
Oh, I thought you posted how to replace the STUD.
S but still applicable = https://www.jaguarforums.com/forum/s...res-fix-59396/ |
If anyone would like to get rid of the stainless steel covered caps on the original nuts, that constantly deform using the original provided lug wrench instead of buying and keeping a proper sized 6 point socket in their trunk (boot). Or allowing shops to use impact guns that really bugger them up and WAY over tighten them. I understand these one piece nuts fit the X Type = Dorman 611-229
Had the same problem with factory stud snapping
Originally Posted by enreb
(Post 2071084)
next time use these . you would have it done in no time ,and you will save the stud
(Post 2071084)
Troll can't read either
