Camshaft Position Sensor Question to the Experts
Can anyone tell me if the crankshaft position sensor used on the 2.5 & 3 litre V6 engine will also fit & work on the 2.1 Litre engine ?
cam sensors
yes they will,i fitted new ones to mine 2.1L manual,when I had a misfire, fault codes all said cam sensors,but made no difference ,I had to change the plugs ,then all was fine again,good look ,hope this helps ,peter
Peter
I note you say Cam sensors - there are 2 and are different from the actual crankcase sensor. Did you just make a typo or what ?. In my case I had this trouble prior to a service, new plugs were fitted during this service and still this made no difference. These cars are problematic for sure. Anyhow thank you for your much valued reply. |
sorry I missed a line out,i changed the crankcase sensor aswell it is the same as the 2.5 3.0 ,and is situated behind the inner wing shield which you will have to remove plus front wheel,driver side RHD passenger LHD it is at the bottom of the engine it cost about £9.00 GBP hope this helps ,ps I had great help from a guy called THERMO on this site to fix my problem, look him up ,nice guy ,good look peter
Peter
Yes I thought so - anyway I now know where to access this part. Thermo is a fantastic and helpful member, and from my own recollection has assisted many poor souls in distress. I now only await the arrival of a shiny new CPS from the states (much cheaper in spite of postage charges) |
