Can't disable auto door lock X Type!
Old Mar 8, 2014 | 03:57 AM
v6jon's Avatar
Default Can't disable auto door lock X Type!
I want to disable the auto door lock feature on my UK model 2002 3ltr X Type. We find this feature very annoying when you pick someone up as you have to lean across or behind to unlock the passengers doors. Also there is the worry that it will not be possible to open the doors from the outside in the event of an accident. Not a good feeling when children are in the back.
I have found a proccedure in this forum but it does not work or I am reading it wrong or I have a fault with my locks but all other locking features work.
Turn on ignition. Lock the door, using the door handle lock, and unlock 3 times.
Turn off the ignition. Lock and unlock the door 3 times.
Turn on the ignition. Lock and unlock the door once.
There is mention of the car beeping or chirping but I am getting nothing.
I have tried several things such as speed of locking, locking all doors first, setting the auto lock first etc.
Old Mar 8, 2014 | 05:29 AM
Five Speed's Avatar
I think what you tried is reprogramming key or something . I believe disarming auto lock is a dealer fix only . Pull ing lock catch back on drivers side should open all doors to take on passengers ( I think )
Old Mar 8, 2014 | 05:48 AM
v6jon's Avatar
Thanks for the reply fivespeed. The process for programing the key is different. I'm sure I read the correct procedure for the auto lock but am now wondering if this only works for foreign models. The drivers door does not unlock the others but even if it did it still does not get over the issue of opening from the outside in the event of an emergency.
Loving the car but the locks are a pain. I suspect Gloucester is the same as Frome i.e. not exactly over run with car jackers.
My old Renault had the best system, a button which I could press if I wanted the doors locked!
Old Mar 8, 2014 | 06:01 AM
Five Speed's Avatar
Yea I see what you mean ! Stepdaughter used to live in Trowbridge ...she took us to Car Boot sale in Frome once .....Wow claim to fame ...
Old Mar 9, 2014 | 08:14 PM
Pinecone's Avatar
Jon, I know what you are going through. I tried the procedure three separate times and it never worked. I had given up, but one day last December while waiting in a parking lot to pick someone up...I tried it again. Just to pass the time more than anything. Out of the blue, after the last sequence of locking/unlocking...the car suddenly chirped the horn once. It hadn't done it before. I started the car and put it in Drive....and it didn't lock the doors. Hooray!
I really don't know what I did differently other than begin much faster and smoother with the unlock/lock routine. Perhaps cause I had so much practice by that time. Anyway...I suggest you give it another try. If that doesn't work, then try it again some time when you really don't care if it's going to happen or not - that might be the approach the car expects. Oh yeah, the online tip said the car would 'chime' when the program was successful. Nope, my car beeped the horn instead.
Good luck, hope it helps.
Tom
Old Mar 10, 2014 | 01:10 AM
v6jon's Avatar
Thanks Tom. Sounds like there is still hope. I will persevere and let you know how I get on.
stanjag
Dec 29, 2024 08:26 PM
msdg137
Sep 16, 2015 06:24 AM
Thia
Sep 1, 2015 10:36 AM
ogorir
US Southwest
Sep 1, 2015 10:05 AM
plmmd
Aug 31, 2015 10:07 AM
